170 hydraulic control linkage question
Toddmac66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toddmac66 Quote  Post ReplyReply Direct Link To This Post Topic: 170 hydraulic control linkage question
    Posted: 07 Aug 2026 at 9:05am
Howdy, I need to see if anyone with a 170 or larger that uses the same design can help me.   I have converted my D17 series 4 to 170 fenders. I discovered the pivot pin for the hydraulic levers isn’t long enough.
I just need to know if the 170 uses the same design where it’s a machined surface for the linkages to pivot on and then has threads that pass thru the fender to secure it or is it a long smooth pin on the 170s.
I can’t find a pic of the assembly on one and I don’t own that parts manual. If you have one and happen to have a pic of the setup, that would be awesome.
I have a feeling I found an unmarked pic of what it could be and it looks like a much longer pin with a support added to it for the inside. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2026 at 9:47am
Same design but at least an inch longer in the threads to go thru the fender brace.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toddmac66 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2026 at 10:34am
Thank you for confirming, I was hoping so but saw that other design and was concerned about that.
This page was generated in 0.060 seconds.
