Allis Chalmers sickle bar mower
Jefffafa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jefffafa Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers sickle bar mower
    Posted: 13 Nov 2025 at 6:00pm
Hi. I have an allis Chalmers 80R3 sickle bar mower. I was wondering if 10w 30 or 40 oil would be good to use in the gearbox?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2025 at 7:32pm
I would use 90w in it. Tracy.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2025 at 8:12pm
80/90W Gear oil. Tractor supply carries it in two and five gallon containers. Auto parts stores have it in quarts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jefffafa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2025 at 12:31am
Ok thank you 👍
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2025 at 5:17am
If it leaks some go with some or all John Deere corn head grease.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2025 at 6:39am
All good suggestions
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2025 at 11:58am
A couple of things on those Twin-Wheel drive mowers:  #1. Keep the sickle head bolt TIGHT. This bolt must be a grade 8 quality. #2. Make sure the serrations in the bushing this bolt clamps thru are CLEAN when assembling. #3. Keep the cross-arm snug against the bushing. Any looseness in any of these parts leads to quick destruction of said parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jefffafa Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2025 at 2:32am
Ok thank you. I'm just a dabbler with tractor stuff. I have a Kubota L3400 compact tractor with a few attachments, and a neighboring farm had the sickle bar mower, which has been sitting outside for maybe ten years not being used, so they said to try it out. So I'm trying to get it back in running condition hoping to buy it. I'm trying to get all the adjustments as close to what I think they should be, to fit my tractor. (they didn't have an owners manual since they bought it on consignment). On a short trial run, I thought it mowed half decent...Does anyone know what it may be worth?
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2025 at 2:44am
I just bought one last summer that need work for 300
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2025 at 9:37am
Several years ago I asked the same question on here. One member recommended, straight 30 weight non detergent oil. That oil has worked well in the mower.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2025 at 10:29am
I still use 30 wt. in my 80R mowers.
From the lubrication chart on page 4 of the 80R manual: Drive housing capacity, 1 qt. SAE No. 20 or 30.  Do not let oil level get below or do not fill above drive shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2025 at 1:19pm
dont mix gear lube and engine oil... Use one or the other.. Always flush if you change... Years ago i had a mechanic top off a dozer final drive with 15W40 in a 80-90 wt gear case.. Turned it into a black goo after a couple weeks.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 6:49am
[QUOTE=DrAllis]A couple of things on those Twin-Wheel drive mowers:  #1. Keep the sickle head bolt TIGHT. This bolt must be a grade 8 quality. #2. Make sure the serrations in the bushing this bolt clamps thru are CLEAN when assembling. #3. Keep the cross-arm snug against the bushing. Any looseness in any of these parts leads to quick destruction of said parts.[/QUOTE
To add to this, a drop of red loctite on the threads doesn't hurt. Only way I could get mine to stay tight.
kevin LA-CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 9:44am
I was mowing with dads 82s. Had to remove the sickle to replace some sections and had a few questions regarding reattaching.
Only the head end has serrations? The bushing appears smooth on both ends.
The threads in the head end are partially stripped. Is a helicoil strong enough for repair?
How tight is tight for the cross bar ? I am afraid of cracking the casting. This one runs quiet.
Edited by kevin LA-CA - 16 Nov 2025 at 9:46am
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 3:39pm
Very early crossbar bushings were plain faced. Later ones had a serated face.
When I rehabbed my 82S, I used some parts from different mowers including a #7 and even that had the serated knifehead and bushing.
I have never even seen a smooth faced bushing but I know there must be some out there yet.
I don't think I would ever mix the two styles.
I would be looking for the matching bushing but I understand the serated bushings are scarcer than hen's teeth anymore.
That might account for a prior owner settling for the wrong bushing.
The threads on my knifehead were almost "shot" so I welded a quality nut on the bottom of the knife head. I only had to grind off a very little of it to make it easily clear everything on the under side  of the cut bar.
It has worked perfectly for years.
You definitely want this bolt to be tight and a Grade 8 bolt is definitely in order here.
You are fortunate to have an 82S mower.
It and many of the other later built "Twin-Wheel" mowers have many improvements over earlier models.
One of the biggest improvements was the change from the 5/8" thick  to the 3/4" thick cut bar.
The housing that surrounds the gear box is also made of much heavier material.
Another big improvement was the change to ball bearings rather than steel on steel on the gear box support (I call it the "hinge").
When set up correctly, the 82S is a smooth operating and durable piece of equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 4:54pm
The serrated sickle head and bushing are by far a better and more durable design, but again, that bolt must be kept TIGHT. Also, a dull sickle just adds to the stress of that whole area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2025 at 7:10pm
For what it is worth, looks like Allis changed to the channel type head and bushing midway in the production of the new style twin wheel.
The parts book lists both part number pairs (head and bushing) for plain and channel type. An inattentive reader could easily order the wrong match part. Guess that is what happened to Dad's.
Looks like serrated bushing can be bought.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 8:35pm
For what it's worth - I have drilled and rethreaded the knife head and bushing to 9/16" after stripping threads on original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2025 at 10:36pm
Make sure to keep the head greased well as the serrated bushing rotates back in forth with the action of the sickle. Great mowers, visibility of the sickle while mowing is wonderful. No turning around to see what’s going on. Best mower AC made IMO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 39 minutes ago at 6:33am
Do yourself and the mower a big favor buy a new complete sickle assembly from Webbs Sickle Service.I have bought several dozen sickle mowers over the years and None as in Zero had sections in them I'd take to the hay field and cut hay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 48 minutes ago at 7:24am
In the old Pitman-stick days, you had to keep the sickle very sharp or you'd break the wooden stick !! Twin-Wheel drive was tougher than a stick of wood, so it was more forgiving. And then people complain about the bolt/serrated spacer working loose !! maybe enough dull sickle time did that !!
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 30 minutes ago at 8:42am
There were smooth sickle bars and serrated sickle bars, and each had their own use/applications, but I don't remember which was used for alfalfa and the other might have been for straw.  Someone please educate me.
This page was generated in 0.045 seconds.
