Check your filters, guys…………… |
DanielW
Topic: Check your filters, guys……………Posted: 6 hours 19 minutes ago at 8:13am |
Well I'll be jiggered: I spoke too soon! Only a couple weeks after my reply above where I said I use whatever filter I can get easily and quickly (and after hundreds of thousands of miles using economy filters) and having never had a problem, I actually had a filter fail over the weekend. This was on the aforementioned Titan with 420,000 clicks on it. But it was actually a Fram 'ToughGuard' filter, which (according to what I read online for that filter #) is made in the USA.
It wasn't a catastrophic failure, just a very slow drip I noticed after checking my oil and seeing it was low (truck surprisingly burns no oil, so I was curious to find where it was going). Turned out one of the spot welds on the filter that holds the gasket flange to the outside of the can must have broke when I tightened the filter up - causing part of the gasket surface to recess slightly and not seal. I've never really bothered to to check that I'm doing exactly the 'contact plus half a turn' (or whatever they recommend when tightening). I just tighten as much as I can by hand - no tools or wrenches. But I can't believe the force from me just screwing it on by hand should have been enough to break the spot weld. Very unimpressed. The replacement filter I got was a generic, Canadian-Tire economy one that was made in Mexico, but it has twice as many spot welds around that rim as the Fram one did.
Edited by DanielW - 5 hours 40 minutes ago at 8:52am |
Joined: 11 Sep 2009 Location: illinois Points: 88582 |
Posted: 20 Oct 2025 at 7:41pm |
In my opinion, regular filter/oil changes and using synthetic oil are more important to me than where the filter was made or if it's a supposed 'premium' brand. A couple decades ago I would have been concerned with where the filters were made, but not so much anymore. Not that I disagree with wanting a high-quality filter. I just doubt that any manufacturer has any wonderful secret or revolutionary QA methods that would make them so much better than others.
very seldom ( if ever) does an engine fail because of bad filters.. Normally they just wear out or something breaks...Any more a LOT of the filters are made in Mexico and China...that being said, i use only MOTOCRAFT filters in my FORD Truck engines...they have an antidrain back valve in them.. Had trouble 15 years ago with motor TICK on startup due to low oil pressure..
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2200 |
Posted: 20 Oct 2025 at 7:24pm |
Shoup has a very good selection of Baldwin for older models. I buy 90% of all my filters through there catalog. From the 8070 back to the UC. If I place an order before noon, it's here the next day.
Leon B Mo |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5163 |
Posted: 20 Oct 2025 at 2:55pm |
DanielW : Do you remember years ago when WIX remade the packed cotton type filters our Allis Chalmers engines with the Bypass filtration system requires with a pleated paper design? You must not. These filters caused very low oil pressure and ruined many engines. As the saying goes "Fool me once, shame on you. Fool me twice, shame on me." And to that I have to add if I allow myself to be fool the second time, I'M an idiot.
DanielW
Posted: 20 Oct 2025 at 12:09pm |
Napa here sells both economy and premium filters. Both labelled as Napa, both made by WIX. The premium ones are made in North America (most often in Mexico, but the larger cannisters are typically USA), the economy ones are made in China. They usually have good stock of all the economy ones, but premium ones often have to be ordered in.
Other folks will rightly criticize me, but these days I put on whatever filter I can buy quickly and locally. Which for me is usually Napa economy ones, but sometimes Fram. I suspect they all have similar micron ratings, and I've never known any oil filter to fail (not in the last couple decades, anyway). Doesn't seem to bother my equipment. My Nissan Titan just rolled past 420,000 km a couple weeks ago, having used nothing but the Napa economy filters. And still runs like a top and pulls my 16' float around regularly. My old daily-driver Toyota Matrix beater had over 600k on it when I scrapped it. Engine still ran like a top, and it also saw nothing but economy filters (I'd still be driving it if I hadn't smashed the front end up on a deer). In my opinion, regular filter/oil changes and using synthetic oil are more important to me than where the filter was made or if it's a supposed 'premium' brand. A couple decades ago I would have been concerned with where the filters were made, but not so much anymore. Not that I disagree with wanting a high-quality filter. I just doubt that any manufacturer has any wonderful secret or revolutionary QA methods that would make them so much better than others.
Edited by DanielW - 20 Oct 2025 at 12:20pm |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8157 |
Posted: 20 Oct 2025 at 5:27am |
The only parts stores in the little town I live is O’Reilly’s. The previous time I changed oil on this car, O’Reilly’s had Honda OEM filters, and those were stamped right on the filter ‘Made in USA’.
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1116 |
Posted: 19 Oct 2025 at 10:40pm |
Most Carquest brand filters are made by Baldwin.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8681 |
Posted: 19 Oct 2025 at 9:56pm |
Recently got AGCO boxes with wix filters inside....
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1076 |
Posted: 19 Oct 2025 at 9:47pm |
Napa uses different suppliers now depending on what part of the country you’re in. Our region uses hfi for auto and Baldwin for hd oil and fuel. Donaldson for air
977.3Ford
Joined: 04 Oct 2019 Location: Dayton, Ohio Points: 103 |
Posted: 19 Oct 2025 at 9:40pm |
Wix was bought out by Mann + Hummel a while ago, and i've noticed a big shift overseas since then, although i assume it started long before the merger. For the tractors/combine i primarily run Agco filters since they are usually a good bit cheaper than parts stores. Seems like they are all made in the U.S., i'm curious who is making them for Agco. Seems like at one point i got a hydraulic filter that was a regular Baldwin in an Agco box. I really need to start looking into Baldwin filters. Over the winter i was at a heavy duty parts store getting some stuff for our grain truck, and grabbed a set of Baldwin filters for the DT466. I don't think i paid over $60 total for 2 oil and 2 fuel filters. All made in the U.S.
Jimmy
1982 8050 Powershift 1982 6080 1992 R52 Gleaner |
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1791 |
Posted: 19 Oct 2025 at 8:56pm |
Exactly. I’ve seen Wix and Napa filters with China printed on them.
PaulB
Posted: 19 Oct 2025 at 7:25pm |
Ever since the fiasco WIX tried to pull off years ago selling redesigned ElCheapo filters for the bypass systems of our Allis Chalmers engines, I have refused to by any WIX or NAPA filters for anything.
I prefer to get Fleetguard filters, Baldwin filters are also acceptable.
Lars(wi)
Posted: 19 Oct 2025 at 6:18pm |
Went ahead and changed oil in the wife’s car today. Got the WIX filter, all ready to go, put a little oil on the gasket, some on the threads, spin it on, as I was tightening it down(by hand of course), I noticed the a sticker on the side, and it said ‘Made In Mexico’, holy crap wtf is this all about, a WIX filter non-the-less. O well, cross WIX filters off my list.
