Allis Chalmers D14 Head Bolts |
ForeverHomestead
Topic: Allis Chalmers D14 Head BoltsPosted: 15 Feb 2024 at 4:46pm |
Hello All. I am putting my D14 back together and thought maybe I could get away with reusing my head bolts (I know I am not supposed to) as I am having a hard time sourcing new ones. However when I was tightening them down, two of them stripped the threads. So now I am on the hunt.
Can I use grade 8 bolts? if not, does anyone have a source for them they can send me a link to?
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5274 |
Posted: 17 Feb 2024 at 6:47am |
Grade 8 bolts will be fine if you find the correct length. IFIRR some are on the 1/4" increment, most places only stock the 1/2" increment sizes.
You're lucky that the treads stripped off. Many years ago when reusing old bolts, I've had them break just as I was getting to the final torque. I never reuse head bolts any more.
Posted: 17 Feb 2024 at 7:07am |
Be sure to run a bottoming tap down each and EVERY head bolt hole and with compressed air clean them all out good. Wipe some grease on the threads of the head bolts for lube.
ForeverHomestead
Posted: 17 Feb 2024 at 7:09am |
thanks for the help guys. I did clean the threads out with a tap. I found a match on length and installed them yesterday .
Mikez
Posted: 17 Feb 2024 at 8:10am |
Looks like head bolts are still available
