What model do I have? |
Page 12> |
CronyTJ
Topic: What model do I have?Posted: 19 Sep 2023 at 7:03pm |
Hi everybody I just scored a D series but I’m not sure if it’s a 10, 12, or 14.
It’s only my second Allis I’m typically a Ford and Farmall guy. It has no starter so if anyone has one I’d be interested in buying it. Thanks in advance. Here are some photos. let me know if they load. Tom ![]()
KMAG
Joined: 26 May 2020 Location: Elizabethtown, Points: 690 |
Posted: 19 Sep 2023 at 7:13pm |
D14 or D15 - a photo of tractor nose would help.
Edited by KMAG - 19 Sep 2023 at 7:16pm |
CronyTJ
Posted: 19 Sep 2023 at 7:24pm |
Ah ok even better. If it’s too dark to get a photo now I’ll get one in the morning. Thanks.
CronyTJ
Posted: 19 Sep 2023 at 7:27pm |
only AC orange
Joined: 06 Dec 2014 Location: Eastern Indiana Points: 609 |
Whatever it is, it has shuttle shift on left side!
Joined: 11 Sep 2009 Location: illinois Points: 90838 |
Posted: 19 Sep 2023 at 8:01pm |
how about a serial number
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Posted: 19 Sep 2023 at 9:27pm |
What happened to the muffler?
Why not get a starter for it? From what I have heard over the years, if the shuttle works, those are very good loader tractors. |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Posted: 19 Sep 2023 at 9:47pm |
Heavy duty front axle too.
Posted: 19 Sep 2023 at 9:54pm |
you might message LON and see if he has a starter...
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5476 |
Posted: 19 Sep 2023 at 9:55pm |
I think it’s a D15 industrial, shuttle shift and heavy duty front axle.
Travis2766
Joined: 26 Aug 2015 Location: Amherst, Wi Points: 439 |
Posted: 19 Sep 2023 at 10:30pm |
D14 Industrial??? Serial number will tell what it is, its on the torque tube (left side) where it meets the motor.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 20 Sep 2023 at 6:34am |
what is width of grill 15 is wider then 14 by 2 inch
CronyTJ
Posted: 20 Sep 2023 at 6:40am |
So on left side of bell housing there’s a raised rectangle where it looks like serial number should be. But no number.
Travis2766
Posted: 20 Sep 2023 at 7:08am |
It will be where the yellow box is in the picture, it’s stamped into the casting and is very hard to see sometimes.
CronyTJ
Posted: 20 Sep 2023 at 7:55am |
![]() Nothing there |
Posted: 20 Sep 2023 at 8:01am |
ON TOP, not the side.
Travis2766
That’s below where the highlighted yellow box is. Go higher up on the same flange, above the upper bolt in your picture.
CronyTJ
Posted: 21 Sep 2023 at 9:42am |
Whoops. Just saw your reply. I’ll look today and check back. Thanks.
CronyTJ
Posted: 21 Sep 2023 at 12:38pm |
Well look what I found
Posted: 21 Sep 2023 at 1:15pm |
Travis2766
Posted: 21 Sep 2023 at 1:52pm |
D15 7053??? If I’m seeing that right you have a 1961 series 1 D15 Industrial, the standard D15’s have the “big stick” on the right side of the torque housing and that created a high and low for each gear. The industrials have it on the left side and it created a forward/reverse shuttle.
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3252 |
Posted: 21 Sep 2023 at 3:30pm |
Maybe I missed it , but is it a diesel ? If so , you may have a hard time finding a starter . Hope not , good luck .
CronyTJ
Posted: 21 Sep 2023 at 4:41pm |
Nice! Thanks for all the info.
It’s a gas job. Hope starter isn’t hard to come by. And I was wondering what the big stick on left was. The shuttle will be handy. |
ACinSC
Posted: 21 Sep 2023 at 4:54pm |
I would think a gas starter would be pretty easy to find. Steve at B and B might have one.
Les Kerf
Posted: 21 Sep 2023 at 5:12pm |
That is one bodacious winch on there
I like it! |
AC720Man
Posted: 21 Sep 2023 at 7:27pm |
In the first picture it looks Ike the front support power steering vent has been screwed into the transmission oil level hole below and to the left of the key?
Mikez
Posted: 21 Sep 2023 at 9:31pm |
Robbie our D14 industrial, shuttle clutch has the same vent
AC720Man
Posted: 21 Sep 2023 at 9:35pm |
That surprises me, don’t recall the D15 industrial I tried out having that. Thanks for correction. Guess I was to busy testing the shuttle clutch lol. I should have bought it...it went cheap
Mikez
Posted: 21 Sep 2023 at 9:38pm |
Not saying it’s right lol. Interesting
Mikez
Posted: 21 Sep 2023 at 9:45pm |
Just looked in d14 parts book. Gives three different part numbers. First just says gauge assy, oil level. Second says same and base tractor in parentheses. Third says same and for utility tractor with shuttle clutch in parentheses
Page 12> |
