Evolution of the "226" engine
Post Options Post Options   Thanks (4) Thanks(4)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Topic: Evolution of the "226" engine
    Posted: 16 Dec 2022 at 8:40pm
There's been lots of confusion and misinformation over the decades on the A-C "226" gas engines. Many (who think they know) have said that the D-17 is the same engine as the WD-45, just revved up some more. Well, both claims just ain't true. While many parts do interchange between them, some simply do not. The G-226 engine used in the D-17 tractor evolved from the W-226 engine that came from the WD-45. The changes were somewhat minimal, but nevertheless, needed to be done for reliability and performance. While the 4 inch bore and 4 1/2 inch stroke remained exactly the same, yielding the 226 cubic inch displacement, there were only three things that were changed in the new G-226 from the old W-226. The block, the crankshaft and piston compression were the only things redesigned. The block casting was stronger/heavier and had a horizontal reinforcing rib down each side. These reinforcing ribs are very obvious when both a W and G block castings are side by side. The G-226 blocks also have larger 3 inch diameter main bearings, instead of the 2.400"+ diameter mains used in the W-226. This area had to be beefed up to withstand the compression and rated speed increases. So, with larger diameter main bearing journals on the crankshaft, it was a stronger piece of steel. So essentially, the cylinder heads are the same, manifolds are the same, carburetors and camshafts are the same, as far as making HP goes. It took compression being raised (from 6.5 to 1 up to 7.25 to 1) and rated RPM (from 1400 to 1650 RPM) being increased 250 RPM to get the performance to where engineers and salesmen wanted to be. The W-226 produced 50.6 flywheel HP @ 1400 rated RPM in the WD-45 tractor. The same engine produced 56.1 HP at 1600 RPM and 60.0 HP at 1800 RPM, all flywheel HP. So, when the compression is increased, the G-226 makes 55.6 HP at 1400 RPM, only 5.0 more HP than the WD-45. But if you increase the RPM to 1650, you get 63.2 HP. And at 1800 RPM, you get 67 HP.  So, you see that the new D-17 engine compared to the WD45 engine (with both at their rated RPM) produces 12.6 more HP at the flywheel. When you add power steering to the D-17 (which it was Nebraska Tested with) it brings the PTO HP to an almost 10 HP improvement over the WD45 it was replacing, 43 to 53 HP on the PTO. The G-226 went thru a few improvements over the years, with the first of which being long reach spark plugs, then the full flow oiling system and finally the nitrided crankshaft journals, which resisted wear much better. I have overhauled many a D-17 series 4 tractor and never had to re-grind the crankshaft on the first OH.  In my opinion, that generation of G-226 engine was about as good as it got when it came to long life. I don't think any of the competition had 4000 hr life on any of their gas engines back then. The G-226 still lived on until March of 1976 thru the 170 and then in the 175 tractor, and by then may have been rated at approx 73 HP at the flywheel (61 PTO) at 1800 RPM. And to think, it all started in 1934 with the W-201 used in the WC tractor !!
Edited by DrAllis - 23 Jan 2023 at 6:35pm
tbran View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2022 at 10:00pm
Good anaysis. Also as you pointed out the crank is different and also had the thrust bearing changed from the front main to the middle on the D17.  Ithin I am also correct in that the G226 in the 175 was the only AC engine to have the cam changed to improve performance.  The cam was changed on the D262T in the first few D19s but then programmed back to the old profile due to cold starting issues. I have long stated cam research was lacking out of Harvey.  One knows there could have been improvements in performance and economy from the first 3400 to the last 670HI...
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2022 at 10:05pm
The 175 gas (as far as I've ever been able to determine) was the only grind change since the 1934 WC. There have been different p/n cams, due to a bolt on gear or pressed on gear, fuel pump capable  or not and oil pump drive gear tooth count.
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2022 at 10:07pm
Thanks for that great info, so did a series IV d17 have more rated hp than the series 1?
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2022 at 10:12pm
D-17 gas engines always had 63 FLYWHEEL HP from 1957 til the end in 1967. The actual PTO HP was less because of the "live" hydraulic system, which took away 2 to 4 HP compared to pre-S4 models.
captaindana View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2022 at 4:46am
Thanks Doc, what an earful to wake up to! What a history! I love those 201’s and 226’s. Grew up with them, counted on them for a living, maintained them and prospered with them. And to think where they all started from! I wonder who was the guy way back then that first came up with the notion of making a 201 cu in motor??? His idea put on paper then into production changed the world!
Blue Skies and Tail Winds
                          Dana
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2022 at 6:25am
The 175 gas (as far as I've ever been able to determine) was the only grind change since the 1934 WC...
Fascinating!
Modern camshaft design could easily improve performance while actually reducing peak acceleration changes (Instantaneous Rate Of Change), resulting in less stress on the valve train and longer life.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2022 at 8:13am
Great info Doc! I enjoy reading interesting engine tech over the years. Imagine how those engines would've ran with a roller cam, lifters and rocker arms from the factory as Les mentioned with modern cam design of today. Those engines would be even more "bullet proof" as well as the HP rating being possibly even a little higher.....
Steve@B&B
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2022 at 11:54am
Even a better flowing head would have been a major improvement.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2022 at 12:17pm
When I look up the D17 on "tractor data", why does it show such a severe drop from "63" engine horsepower to "48" draw bar (tested) horsepower? That seems like a significant loss from power steering/etc systems and friction. Error in the data? Or the testing firm used a fixed rpm for all the tractors so if a particular product used higher revving to achieve marketing hp the figures differed?
Which got me thinking about sales figures for market impact (including market longevity), figures from the Tractor Data site:
WC: 178,000 first sold at $1,300
WD: 131,000 first sold at $1,800
WD45: 90,000 first sold at $2,400
D17: 85,000 first sold at $5,400
Chasing higher horse power, at higher prices, reduced the number of units they could sell between model changes.
By the late 1970s/80s on that other thread where AC refused to send their latest product to Nebraska Testing (sixteen tractors needed) -- that was likely a significant portion of their total production that year because unit sales had fallen so precipitously with the chase for larger tractors with more horsepower so they can cover more acres to "finally be profitable!"...
Edited by jvin248 - 17 Dec 2022 at 12:22pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2022 at 12:57pm
63 engine flywheel HP is the bare engine, minus the generator and fan. A 10 HP drop to 53 HP at the PTO is totally acceptable. The engine is spinning every transmission gear, Power Director clutch & gears, PTO gears, hydraulic pump and finally the generator, radiator fan and power steering pump. All of those things take some HP to operate. So now you are only talking a 5 HP drop to 48 HP, which then goes thru the ring and pinion, differential and final drives. Every shaft, bearing and gear turned requires HP to do so.
Edited by DrAllis - 17 Dec 2022 at 12:58pm
AC7060IL View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2022 at 1:13pm
DrAllis what was the G226’s torque ratings? Dad’s Wd45 & D17 series 1 always seemed to impress when it’s loads heaped up. Thanks for sharing. Great AC history read!!
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2022 at 2:00pm
Peak torque of 211 ft lbs lugged down to 1,100 RPM's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2022 at 2:24pm
Those little engines have a lot of power and pulling guts for their size. Have dad's WD & my 45. Done lots of plowing, discing and dragging with both in the "old days".
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2022 at 2:54pm
Is that listed on AC engine’s specs bulletin? If so, where could one find such info? Listed somewhere on Nebraska test? Is it perhaps measured on tractor(WD45,D17) pto dyno? Mathematically figured ~ Torque=hp x 5252/rpm ? Or measured by AC on just engine dyno?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2022 at 3:40pm
I have an early 1960's "Power Units" sales book that has all the information I have listed.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2022 at 6:08am
That $1,300 WC in 1935 would have sold for $2,800 in 1960 if it were new along side the D17.  It also didn't have electric start, lights, hydraulics, a lift, or a Power Director.  It wasn't only horsepower they were chasing.  Creature comforts and usability were huge.  The same thing happened with Farmall.  The $1,400 M wit 270,000 sold vs the $5,500 560 that sold 66,000.  Farmers wanted increasingly more options, power, and usability.  That necessitated changing designs faster.
AaronSEIA
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2022 at 8:10am
One 7000 at 106 HP did the work of two D-17's at 53 HP each. Engineers were working themselves out of customers to sell to. Same amount of land and fewer farmers.
Tom59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom59 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2022 at 8:13am
Years ago in tractor brochures the manufacturers gave PTO horsepower and drawbar horsepower. Don’t remember seeing engine horsepower advertised in the seventies and eighties. I guess I remember seeing engine horsepower listed was about twenty to twenty five years ago. It was about eight years I realized the manufacturers more focus on the engine horsepower of tractors when selling then.
But I always look at the PTO horsepower of tractors I look at buying because it was the minimum PTO horsepower or drawbar horsepower that was needed listed in manufacturers implements and equipment brochures.
I think today to many tractor buyers are looking at engine horsepower and not focusing on the PTO horsepower and they are not really buying the size of tractor they need.
jrbynf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrbynf Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2022 at 1:24pm
Great thread Dr Allis. Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2022 at 8:14pm
When Kubota entered the market they advertised engine hp - that is less alternator, hyd pumps and water pump.... a worthless measurement, but when they entered the market they leap frogged competition as those early buyers had no idea of eng vs pto vs drawbar hp... and still don't. It didn't take everyone else long to catch on and start advertising eng hp..  ( we lost a lot of sales to Kubota - we were selling 5020's -5030's at 21 and 26 Hp -PTO hp before we caught on that these were about 2 sizes above the same engine hp units - we didn't win any Einstein awards)
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2022 at 11:20am
So true!
Allis dave View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2022 at 6:54pm
Add this to the knowledgebase
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2022 at 7:56pm
Where would the "Z" code Gleaner engines and the model "17" engines used in cotton strippers fit into this timeline?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2022 at 8:23pm
As I understand it, a "Z" code means 8.0 to 1 compression ratio, which should be a One-Seventy engine. So, the serial number should be 7- XXXX -Z  and that should be 1967 til 1973 ??   A D-17 engine serial number is 17- XXXX -M for a gasoline engine and maybe "V" for an LPGas engine and ran from late 1957 til mid 1967.   I think the 175 engine serial number would be 77- XXXX -V from 1973 til early 1976. **** EDIT: I'm a little confused on the 175 gas engines s/n.  My 175 owners manual gives reference to 7- XXXX- Z, which cannot be correct, as the compression code should be "V" for 8.25 to 1.  Nebraska Test lists the test tractor engine as 77100 with no letter code. So, if someone has a 175 gasser, could you please look at your engine s/n and report back ?? Thanks.
Edited by DrAllis - 22 Dec 2022 at 7:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2022 at 6:10am
Wasn't the Gleaner E (that had the Z and M code engines) production ended long before the 170 (maybe even before the D-17)?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2022 at 6:56am
1968 was the last year for the "E" series. Sometimes the Gleaner line had an engine before the tractor line. Example: F-2 had the 4-cyl turbo engine in Fall of 1977 (78 model year) and the 6000 series came in Fall of 1980.  *****   EDIT: If someone actually has a 175 gas tractor, would you please check the engine serial number for me ?? There is conflicting information between the owners manual and Nebraska Testing.  The owners manual I have says the engine s/n should read 7- XXXX- Z, which I believe is wrong. That is a 170 engine format, as the Z should be a V.  Nebraska Test says the tractor that they had, the eng s/n was 77100, not 7-7100-V, which I think it should be or 77-7100-V. Can any owner shed some light on this please ?? Engine s/n is stamped on the block just behind and rear of the carburetor. Thanks.
Edited by DrAllis - 22 Dec 2022 at 5:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2022 at 5:40pm
BTT for some help.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 6:48am
How do you think the 226 compares to other motors of the time?
Ford had the 134-172 ci  motor line that they used for a lot of years.
JD had the 134 ci line also (1960's)
Case had their 148 ci motors
IH had 169-175 ci motors.
AC seemed to be on the upper side of engine displacement in the class
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 7:34am
The G-226's biggest weakness, was poor oil pressure/dirty oil. Once they went to the "full-flow" oiling system, that engine was the best they had had to date in late 1959. So, the first two years of G-226's were maybe a little suspect. I have seen several over the last 45 yrs that still had the old oiling system on them and they survived. But, I also know of an old customer who had an old D-17 and he claimed he had nothing but trouble with crankshaft/bearings/oil pressure that he finally had to get rid of it, and switched brands. I believe those old original oiling system engines were probably failing in the heavy tillage applications, where engines performing lighter jobs didn't have that much trouble. By the time the series 4 came along (with the nitrided crankshaft journals) that was another step forward. I think the competitive engines you've listed would compare more to the 40 HP class instead of the 50+ HP class. The Ford engines were a good cheap engine, using a cast iron crankshaft versus the A-C forged steel crank and a parent bore block instead of wet-sleeves. The G-226 family was ALWAYS the easy overhaul "wet-sleeve" design, which cost more money to build, but service-wise was the best idea there was. No time consuming block boring. Just knock out the old sleeves and drop in new ones !!  If I had an improvements wish list for the G-226, it would have been sodium filled or stellite exhaust valves, a rubber type rear seal and better manifold gaskets. I may have mentioned this before, but I had a classmate in jr high and high school, whose Dad had a series 4 D-17 AND a 2510 John Deere. Both gas engines. Both rated at 53 PTO HP.  They did all their plowing and discing with the D-17. The 2510 was 180 cubic inches that ran 2700 RPM high idle. The D-17 was 226 cubes and ran 2,000 RPM.
Edited by DrAllis - 23 Dec 2022 at 7:48am
