Power shift wheels question
fourthgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Topic: Power shift wheels question
    Posted: 17 Apr 2021 at 11:38pm
I have a 200 and 7020 that have power shift wheels (18.4x38). I don’t think we have ever needed to move them. Is there a rim that will fit on the cast wheel that can still accept snap on duals that is not a power shift wheel?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 6:04am
Yes, just put eyes in cast centers. Yours probably hook to railed.            MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 7:50am
Yes it has loops on the rails. What do they call the type of rim I’d be looking for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 7:56am
Just a standard non-spin out rim. What are you attempting to do here??  Power shift wheels are needed on some tractors to get down to 30 inch rows. If your clamp on duals now connect to the ends of the power shift rails, if you change to the non-power shift wheel, you'll have to buy eyes for the duals to connect to and you'll also have to buy all the blocks that go between the cast center and the non-power shift wheels.  Also switching connection locations may require longer threaded rods to reach the new eyes as they are farther away from the duals.  I'm having a hard time figuring out your plan ??
Edited by DrAllis - 18 Apr 2021 at 8:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 2:11pm
what's the down side with your set up?
This page was generated in 0.135 seconds.
