Checking compression on a deisel
ksbowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Topic: Checking compression on a deisel
    Posted: 11 Oct 2020 at 9:21pm
Hate to post this but, I want some direction. Let me say I've done nearly all my own mechanic work my whole life. It's always been on gas engines though. I've overhauled several car motors and balance and blueprinted a couple so, I'm not a rookie. I have a 170D and I need to run a compression test to track down a problem. Do I need to fabricate or buy an adapter plate to bolt on with an injector jig for checking the compression? Or is there an easier way? Any help explaining to this 70 yo would be greatly appreciated.
Edited by ksbowman - 11 Oct 2020 at 9:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 9:32pm
Injectors have to be removed and find (or make) an adapter to go in place of the injector body and connect it to a compression tester with a 600 psi gauge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 9:38pm
Thanks Doctor. That's what I assumed. If I could get one where would be the best place to look? Maybe a retiring mechanic I bet. Probably an elusive critter to find. Also Doc, Do Lancaster Balancers go bad often? Have you ever had one that had problems?
Edited by ksbowman - 11 Oct 2020 at 9:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2020 at 9:47pm
Never had one of those balancers go bad, but I never had many Perkins diesels either. Most of my units were larger in diesel form.  An old injector assembly with the guts removed and the nozzle tip sac ground off is a test adapter if you can get it to connect to your gauge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 4:27am
Does a 170 have individual glow plugs?  If so, there are diesel compression gauges that go in through the GP hole...Wink
Edited by DiyDave - 12 Oct 2020 at 4:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 6:27am
Those Perkins engines to not.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 8:51am
Harbor freight has nice low cost diesel compression testers, but get the bigger set for this perkins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 11:32pm
I have a Star Products gauge from the Snap On Industrial catalog. Comparable quality to Snap On without the full Snap On price.
It depends on the engine as to whether they test through a glow plug or injector hole, but in this case it's through the injector hole as the Dr says.
wide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wide Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2020 at 11:23pm
  On the VW diesels I work on
turning the engine over by hand gives me a good idea what the compression is.
 I don't have to worry about the change in volume due to the injectors or glow plugs being removed
or volume of the injector tester being added to the volume of the cylinders.
 That said, I'm sure it's easier to turn a 1.6 or 1.9 diesel by hand than it is a AC 170 diesel.
