180 RoosaMaster inj pump leak
Joe Goodwill View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Goodwill Quote  Post ReplyReply Direct Link To This Post Topic: 180 RoosaMaster inj pump leak
    Posted: 20 Jul 2020 at 6:06pm
My 180 inj pump has a fuel drip when not running. Appears to originate from the backside, where I can’t see!!
All injector lines are tight. Maybe coming from as high as the throttle shaft but not sure. Runs fine.
Any thoughts.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 8:31pm
Probably the shaft seals for the levers.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 9:10pm
can be replaced without removing pump .              MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 9:34pm
Mine does the same but when it is running.  Could this be the same cause?  I just had my pump rebuilt 3 years ago.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2020 at 9:53pm
could be same problem or a seeping inj. line.  Clean area and dry. Sprinkle baby power around area then crank it up. Powder will turn brown or wash off at leak.         MACK
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (1) Thanks(1)   Quote Joe Goodwill Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 6:10am
Thanks.
Mack would I find the seals in my parts book and is it a reasonably basic repair?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 6:29am
you will need two orings one cover gasket. Don't loose retainer clip down into governor.             MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 7:16am
With a flashlite and a mechanics mirror, you should be able to isolate exactly where the leak is coming from.
Luke114 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke114 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 3:11pm
Not on the 180, but did this same repair to a Roosa on a Case.  They seem to be pretty notorious for this drip.  Its simple once you realize you have to pop that little C shaped clip off in the center of the throttle shaft and then pull both halves of the shaft out their respective sides.  That's the clip that Mack says don't drop.
I only mention this because after you pull the cover off, it isn't immediately obvious how that shaft comes apart.  And remember to clean the pump and surrounding area BEFORE you crack the lid because it becomes a wide open dirt magnet.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (1) Thanks(1)   Quote Joe Goodwill Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 4:46pm
Thanks again! I found the seals in the parts book, are they seals or just an oring. Some online chat said an oring works?
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Goodwill Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 5:41pm
Seals are ordered and found a video on throttle shaft removal and replacement
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke114 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 5:55pm
Your video probably shows this better, but here's some pics from the manual.  Not the exact model, but gives you a good idea of what to expect.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2020 at 7:39pm
My 180 was leaking.  Switched from steel washers to copper washers on the fuel line banjo fittings at the pump. Obtained the washers from a diesel pump shop in Wichita, Ks.  Gave him $5 for twelve washers.  He gave me 13 because people seem to loose at least one.
Torque to 420 inch pounds (35 foot pounds).  The ones on the back are real fun (NOT!) to replace the washers and torque.
