Serious Hydraulic leak |
MB 121
Joined: 02 Feb 2016 Location: Waggoner Il Points: 15 |
Topic: Serious Hydraulic leakPosted: 10 Jun 2020 at 4:48am |
I have a serious hydraulic fluid leak all cylinders including loader were lathed re packed and don't leak a drop. Brand new lines. I have degreased the entire tractor it appears the leak is towards transmission selector also had hydraulic control hieght block rebuilt new o rings felt dust seals doesn't leak a drop from it either. It will leak while running or not.
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5910 |
Posted: 10 Jun 2020 at 5:13am |
A little more info would help us help you.
Would assume it is an Allis Tractor you are talking about. Need to know the Model and year ( or Serial Number ) to begin with. |
MB 121
Posted: 10 Jun 2020 at 6:27pm |
1953 WD45 don't have serial number on me I can look it up
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8762 |
Posted: 11 Jun 2020 at 1:30pm |
Did you put the oring between pump and control valve?
MB 121
Posted: 11 Jun 2020 at 4:53pm |
Replaced it when I had control valve rebuilt. Not leaking there it's dry
Posted: 11 Jun 2020 at 6:57pm |
"It will leak running or not"...….Leaks what ???? Hydraulic oil??? or transmission/torque tube oil?? You mention transmission selector?? You know a good picture or two would certainly help.
MB 121
Posted: 11 Jun 2020 at 7:20pm |
Hydraulic fluid. The main place I see it dripping off is the PTO housing drain plug already replaced PTO gears housing seals and gaskets. PTO was 90 wieght by I&T shop manual this is hydraulic fluid. Tried uploading photo says to big not sure if I'm doing something wrong there or what.
Posted: 11 Jun 2020 at 7:45pm |
If you had the hydraulic pump off the tractor, I'll bet you've damaged the gasket reinstalling the pump.
MB 121
Posted: 12 Jun 2020 at 4:42am |
Pump hasn't been off it is strong and runs well mostly everything I've put on it it lifts only thing I found it won't pick up is a large round bale with a spear.
Bret (OH)
Joined: 15 Sep 2009 Location: Blanchester, OH Points: 353 |
Posted: 12 Jun 2020 at 6:09am |
See https://www.allischalmers.com/forum/pictures_topic168921.html for instructions on photo posting.
