Precleaner bowl on a 7060 |
cdreb ![]() Bronze Level ![]() ![]() Joined: 27 Oct 2009 Location: SE-IA Points: 114 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Apr 2020 at 6:54am |
The precleaner bowl cracked on the 7060 I have ordered one from suppliers and they are to small. This has a 10-1/2 base and the others are to small at the base,. I am sure this is a factory install any ideas,,,
B,C,5020,D17,(2)-190XT's,220,D21,7060, Agco LT70
bleeds orange ![]() Orange Level ![]() ![]() Joined: 11 Sep 2012 Location: mt. vision, ny Points: 692 |
DJS tractor parts sells that pre cleaner bowl. # AB-339D $16
Replacement number for 70651270 |
DJS does not, it is to small, he said there is only 3 sizes, so it is the size everyone has also. |
Brian F(IL) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Paxton, IL Points: 2709 |
You might try Donaldson Manufacturing. They're the ones that actually make the plastic bowls. I got one from them but had to go through one of their local dealers.
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3870 |
Got mine from Shoup
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 951 |
Cdreb, what is size of intake pipe pre cleaner is on? Most 7000 series have 4" inlet pipe. IF its 4" try ordering AGCO 70651270 or online from ASAP #157282 @ $16.49. Itll be 10.5" D @ top, 3" tall and inner diam of cone is 5 9/16". Fits my 200, 7000 and freinds 7050. Years back was around some on construction equip that were 5" & 6". Try heavy equip dealers for them, they're scarce.
The big ones weren't from Donaldson and was 30 to 45 years ago on Euclid or Wabco equip. With Detroit or Cummins industrial power.
i took one off an Case/IHcombine and it fit my 7080.
Sherman Farms ![]() Orange Level ![]() Joined: 17 Sep 2009 Location: Centerburg, OH Points: 1663 |
Got mine from Agco.
B, C, RC, 3 wc,2 wd,3 wd45, d15, d17, d19, d21, 190, 440, 7040, 918 backhoe, 12 roto balers, 7 60 combines, 40, 66,2 72,90 super, sp100, Gleaner E, F3, 3 L2, R62, and much more
I will measure it tonite, I know the base, not the top is 10-1/2" that is what is misleading when I ordered it the first time....
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5087 |
That size bowl is used on may applications, from 190XT's to 4020's, to 7060's, various Case tractors, IH's etc, etc. I got mine for the 210 from my Agco dealer buddy, and it was the 70651270. I've taken the air stack off the 210 now, so the nearly new bowl got put on the 7040.
steve fischer ![]() Orange Level ![]() Joined: 11 Jul 2011 Location: sleepy eye mn Points: 988 |
get it from agco cheap ones turn yellow faster from sun
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Wild idea it’s an Allis call your Agco dealer
grinder220 ![]() Orange Level ![]() Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2370 |
I personally would replace the whole precleaner assembly with the standard one from another tractor. I have never liked the looks of those large bowls. 7060s are the only tractor I've ever seen them on also.
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
I just looked up this guys part # on the Agco Site, came up with 7026935 ?? I've not seen a # with a "706" prefix ??
Edited by FREEDGUY - 21 Apr 2020 at 5:27pm |
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3511 |
If all it’s cracked pieces are available, you might try super glueing it back together. About 5+ yrs ago I glued one of mine & it’s still good. It’s used on a regular basis too.
Edited by AC7060IL - 21 Apr 2020 at 6:16pm |
My apologies to InjectorEd , I browsed into the XT parts and sure enough, there was a "706"prefix # for the OP's bowl
That's it, in the pic, I did measure it on the intake tube it is 4". I called the Masseys dealership to order one I hope it is right. Thanks for the help guys, mine is beyond repair, I really didn't want to change it out, with the hassle of chasing down parts,,
