D 10 v D 12 |
Kiwi ![]() Silver Level ![]() ![]() Joined: 23 Jan 2018 Location: New zealand Points: 390 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Nov 2019 at 3:31am |
Hi all just reading a book by Alan C King about the D 10 and D 12 and I can not see the difference between the two is there any other then 1/2 inch in height and length
chuck linn ![]() Silver Level ![]() Joined: 13 Dec 2012 Location: ky Points: 78 |
D10 is 1 row tractor d12 is two row tractor has to do with row width spacing
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24584 |
did the D12 come with high-low tranny, or was it an option ?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21743 |
They both had the HIGH/LOW trans as an OPTION and not in the early models.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53892 |
Only difference is the wider rear side pieces, I forget the correct part name, its the piece between the rear and final drive...
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4533 |
D-10 and D-12 are identical tractors except for the width. As was said before, the D-10 is a one row tractor and the D-12 which is 11.5" wider is a two row tractor. Early ones had a 138 cu.in. engine and NO live PTO. Later ones had the 149 cu.in. engine and independent live hydraulics and PTO. An optional high/low range transmission was available on the Series III models.
BrianC ![]() Orange Level Access ![]() Joined: 16 Jun 2011 Location: New York Points: 1619 |
Look at the steering linkages at the front axle, left side. The d12 has more parts. Google up images of both and compare.
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5058 |
I have a '65 series 3 D-10 with the 2 speed gear box in front of the 4 speed transmission. It will do 16.25 mph.
I like taking it on caravans. It is easy to load on my flat bed trailer I tow behind our class C motor home. Dusty
Brian, you are correct on the steering linkage. D-12 has an extra pivot point to accommodate a wider front axle tread width setting
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6368 |
My D12 on the left has a wider stance the D10 on the right
Charlie
Just so there's no misunderstanding about the optional 2-speed gearbox. It was an under-drive, not an over-drive. So none of the original 4-speeds are any faster, only slower.
underdrive .. great,, that's what I'd like to have to run the 5' rototiller ! The D-14 is a tad too fast.... course I'd have t find a D-12 and build another shed to hide it..
I think if you compare the ground speeds, under-drive 1st gear in the D10/12 is the same as low side of 1st on a D14.
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8450 |
Folks,
Again I learn something about these small Allis D series tractors too! Nice! Great picture of the two side by side! Thanks Charlie! Regards, Chris
To add some more differences, mainly in the Series 2 to 3 change
Fenders, lights, nose weight, foot pedals, controls
Charlie
More stuff
Charlie
and some more
Charlie
You are right. I had assumed that it was over-drive, I had to dig out my manuals and check. Sixteen and two tenths mph is a pretty speed for the hp. Thanks, Dusty
TimNearFortWorth ![]() Orange Level ![]() ![]() Joined: 12 Dec 2009 Points: 2014 |
Awful purty there Charlie, have the twin to your D12 with the live pto and live hydraulics, though some swear they did not exist that early.
The nose weight was an option, along with the grill guard. I have both, thanks to Snowman, He built both.
Dusty
The weight is much needed on the front!
Charlie
Never drove one. With that gearshift shaft bent like that, do they shift OK? |
Yes, same gearshift as a D14/15 has.
Charlie
Forgot to mention the Throttle is different as Allis went with a different brand than what it had before.
One is push and one is pull. Makes for remembering fun when hopping on them
Charlie
thanks for all the posts i want one now it might be a one day thing
RMD ![]() Silver Level ![]() ![]() Joined: 07 Oct 2009 Location: Connecticut Points: 304 |
4th gear in a CA, D-10 or D-12 is definitely a road gear. I remember when I was a kid that our CA would run circles around the other tractors on the road when going farm to farm to cultivate.
Edited by RMD - 25 Nov 2019 at 5:29pm |
MDWilliams338 ![]() Silver Level ![]() ![]() Joined: 19 Nov 2018 Location: NC Points: 476 |
Those are great looking tractors!! I spent many summer days hauling tobacco with a D10.Perfect for the drag middles and smooth sailing from the fields to the tobacco barns.
It isn’t how you die.It’s what you live for.-Daniel Boone |
