WD rear rim size
Souder01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Souder01 Quote  Post ReplyReply Direct Link To This Post Topic: WD rear rim size
    Posted: 07 Sep 2019 at 1:12pm
I am restoring my first WD and I need a new rear rim. I have found one locally for sale but I’m not sure if it’s the right size. My tire size is 13.6-28 on a 12-28 rim (that is what it says on the tire). Below are photos of the rim I am looking to buy. I think it’s a 11-28 but I’m not sure. Anyone know?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2019 at 2:41pm
From your pictures that apeats to be a 10x28 rim.why dont you stick the tape between your rim and center and measure it. I think my WD 45 had 10x28 rims on it
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2019 at 7:02pm
From your measurement, from bead to bead it appears to be a 9" rim.  Would probably work but you should measure the old rim or the rim on the other side and match it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Souder01 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2019 at 4:15pm
Thanks everyone for your help!
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2019 at 9:23am
It sure does look like a 9" X 28"......seems unusual......the narrowest I've seen is 10".
I notice some very legible stamped letters and numbers right under your ruler......I bet you could clean them up real well and find the rim size printed there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2019 at 10:06am
10's, 11's and 12's on WD and WD45's.  D-17's were mostly 13's with some late models maybe 15, but I've never seen one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2019 at 3:23pm
After looking closer, I'm inclined to believe this is a common 10" X 28" rim.
