Allis Chalmers D19 front weights
Anthony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers D19 front weights
    Posted: 07 Jul 2019 at 10:31pm
I was looking at a 1964 D19 today trying to buy it and on the front it had a single wrap around weight. I wasnt like any Allis weights I have see, in other words there wasnt a bracket that came out and flat weights bolted or stacked on it, it curved with the curve of the front grill and bolted on each side. I have seen these types of weights on like a Case 930 but never a Allis tractor. Were these factory weights or something that some foundry made and sold after market, or were they made for another brand and just painted orange and put on the D19. Thanks for your help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 5:15am
http://www.brianahart.net/weights.htm
Scroll down, almost at the bottom of the page...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 7:28am
Technically, that particular weight is behind the grille shell and you can't see it on a D-19. Maybe there's two of them....one on top of the other ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 6:03pm
DrAllis, did you scroll down to 11th  or 12th from the bottom of the page?  There IS a weight that mounts in front of the grille.Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 10:11pm
The wt on this tractor is not like that one, it wraps all the way around the front and is bolted on the sides, not on the front
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 4:36am
By any means, post a picture!  There were aftermarket weights made, too...  If it is cast, and has a raised #, that starts with AM, it is made by allis...Wink
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 5:15am
I'm sure that I've seen a weight like that. If I remember correctly its a Rowe weight. Rowe Foundry made a lot of different weights for A-C tractors and I'm sure other makes as well
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 9:06am
The weight shown in the picture is mounted externally on a D-15 because that's the only way it can possibly fit a D-15. That ain't how AC intended for it to be used. AC intended for it to be used on a D-19 only and inside of the grille shell where there is a void.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 5:38pm
OK, now I see, after reading the picture caption.  My mistake...Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 6:47pm
There was a "u-shaped" weight that was aftermarket for the 17 and 19, I have seen them installed and believe they may have in-fact been Rowe Foundry weights if memory serves.
Utilize the two front threaded holes in the bolster under the grill screen plus engine side rails where drilled/tapped, were big and HEAVY.
Have a picture somewhere of a S1 D17 with them, owned by the son of a former dealer in Stephenville, TX who still has the yard tractor from the dealership.
Brian Ahart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 7:37pm
I believe Anthony is referring to the two piece wrap-around weight shown in the picture below by CALEBnOK.  As I recall, these were made by Taylor Foundry.
Additional photos can be found in this thread:
Edited by Brian Ahart - 09 Jul 2019 at 7:39pm
A-C Weight ID reference and other goodies at brianahart.net
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 9:34pm
Here is a picture of the weight on my D19
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 9:35pm
This is it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 10:27pm
That's my tractor. I now have the cab off.
This page was generated in 0.270 seconds.
