210 puller plowing on you tube
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: 210 puller plowing on you tube
    Posted: 21 May 2019 at 10:23pm
Would anyone happen to know who's tractor it is on you tube posted by
dragined.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 8:32am
That would be me!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 8:39am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 8:42am
Ed,
 Very nice video! Awesome tractor! I need to roll over some earth!
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 10:27am
That was a long time ago. It's evolved a lot since then lol!
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 11:28am
Ed, Where were you plowing?
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 12:24pm
That particular video was outside of Mendota IL on my friends farm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 6:56pm
Ed, 5 more bottoms on that plow and it may have made her grunt some. Lol, sweet 210 you got.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 8:53pm
So is that MK II 3700 engine in that 210 and if so how did you deal with the water pump and radiator being on opposite sides.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2019 at 7:20am
Back then it was still the original engine, and I did some cobbling to get water to the innercooler. It has now been switched to a later style block from an N6. I put the 210 water volute and pump on to fit the radiator. To connect the oil cooler water pipe, I cut the 2 different style water pipes in the middle, and connect it with a 2" long piece of straight hose and 4 clamps. Going to the later block allowed me more room to put an A pump on it, since that what our too hot to farm class allows. In this video, it was still a Roosa .450 pump, 4 X .024" injectors, S300 turbo, and a stroked to 5.5" crank for 468 CID. Power wise it played with that 5 bottom, but pulling tires aren't good field tires, and it would just spin if it had any more bottoms. This farm it worked really nice. 2 weeks before this vid, we plowed at the Bergeson farm south of Seneca, and that ground was much harder pulling.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2019 at 8:18am
Is the stroked crank still AC or did you use q 466 crank?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2019 at 9:18am
AC crank welded and offset ground.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2019 at 11:19am
Ed, thanks for your AC 210 plowing video.
So it sounds like your N6’s stroked 426 (468) engine is comparable to a better smaller block version of an AC 516 (4.4375”x5.5625”)? Any idea what your 468 has for hp?
Edited by AC7060IL - 23 May 2019 at 3:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2019 at 12:33pm
200hp!
Allisplumber View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisplumber Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2019 at 1:05pm
I think you forgot about the 1 in front of that 200 !
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2019 at 3:06pm
long ways from 1200. Was around 400 at the time this vid was done back in 2010. It's over 600 now, but needs to be 750! maybe this year's tweaks will get it there!
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2019 at 3:15pm
https://m.youtube.com/watch?v=TJJ1ZdN22NQ
I think this one is more impressive same tractor I believe.
Edited by exSW - 23 May 2019 at 3:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2019 at 3:31pm
That was even before we plowed with it. That was a lot of fun pulling equipment with a hot pulling tractor lol! I've forgotten about all those old vids we did. So much easier to load to FB now.
