timing a CA
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: timing a CA
    Posted: 27 Apr 2019 at 1:57pm
conventional, non mag ignition, set the static timing with the F on flywheel, right? oddly enough, this bit of info is not in the ops man
I am still confident of this;
Wait for the Lord;
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2019 at 2:08pm
No! Static timing on any engine be it tractor, truck or car is at TDC. On the Allis engines the F will be in the center inspection hole when running wide open with a timing light. I know that you already know that it is TDC on the compression stroke.
It would also be the same as I just posted for the G where the points need to be closed just ready to open.
Edited by Dick L - 27 Apr 2019 at 2:12pm
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2019 at 2:22pm
To go along with Dick's post, here is what is in the service manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2019 at 4:27pm
OK, thanks guys!
Wait for the Lord;
