Rear wiper 7020
Moneypit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Moneypit Quote  Post ReplyReply Direct Link To This Post Topic: Rear wiper 7020
    Posted: 05 Feb 2019 at 5:22am
Has anyone mounted a rear wiper on a 7000 series?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2019 at 6:05am
I've heard of it done using a wiper motor and arm from some model of Deere.
Wink
I am a Russian Bot
Fogarty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fogarty Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 7:34am
We added one to a 7040.
Like Lonn said, it came from Deere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Moneypit Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 9:03am
As much as I hate putting Deere parts on an Allis I’ll have to look into that lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fogarty Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 9:08am
We attached it to the tractor between the window and cab top.
Just used it for blowing snow in winter time and then removed it for field work.
It worked quite well.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2019 at 11:01am
If you drilled a hole up at the top, could the motor from a Gleaner work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Moneypit Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 8:32am
Thanks for the information I’ll have to get out and do some digging around. Will be nice to have for blowing snow
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 4:09pm
This wiper was in the tractor when I bought it. Why don't you buy a wiper set up from a 7000 series and mount it in the back.  Tim
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 4:17pm
That's what I was thinking as well. Does the arm flex enough to open the window?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2019 at 5:36pm
  Its a regular wiper arm. So no problem opening. First time I saw it, I thought no way is that factory. lol  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Moneypit Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 8:18am
So that was an actual factory rear wiper option on the 7000 series?
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2019 at 8:45am
If the Deere wiper is from their later cabs (7800-8100s), it’s likely an ex-AllisChalmers tractor engineer did the work on it anyway. So, all is right in the world.
This page was generated in 0.035 seconds.
