AC 200 pulling a plow |
Bob J Wi ![]() Orange Level ![]() ![]() Joined: 25 Mar 2011 Location: Wisconsin Points: 270 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Mar 2018 at 4:55pm |
I have been looking for a 4 bottom plow for awhile. I found an IH 720 with 4-18s in really nice shape. I want an opinion from the forum members , can a 200 pull this plow? It is a spring re-set plow so the frame is really heavy. Soil is not sandy loam but has more clay than it. I know the red and orange will look funny together. Thanks for any opinions and I did not buy it yet.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21864 |
A 200 without rear fluid and front weights...NO. Good rear tires (especially 38's) with full fluid and front weights, I don't see why not, as long as the Traction Booster system works like it should. A 5 x 16's plow is 80 inches of cut. A 4 x 18's is only 72 inches.
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 956 |
If you are plowing in corn stalks it should be OK. The 4x18" takes a 72" cut a 5x14" takes a 70" cut. IF you'll be in sod you better look for a 4x14" plow. Who wants to tear up a 40+ year old tractor when a implement a bit undersized lets them just play. Also with heavy clay you'll have larger slabs from 18" bottoms than from smaller 14" or 16" widths. It may take a heavier disc to work the clods down. From the great uncle that used to own my farm (1924-1977) there was a clay brick works on it in late 1800's. Still has a spot the size of a football field that some springs when you get in it either the tractor spins out or disc rides up out of ground. IF you work that spot when dirt is damp you just made it hard as rock.
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 33904 |
I own a nice 4-14 AC bottom plow, would not trade it for the world, great device!
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5097 |
we pulled a IH700 4x16 plow behind a Ford 6000 back in the 70s. it had 18.4X38 tires without fluid and 6 weights in the left and two on the right along with 4 of the front weights without problem here in eastern clay. If you can't pull 4 18s behind a 200 something is wrong. A proper adjusted plow is very easy to pull, a poorly adjusted one is harder to pull than a tree stump.
Edited by PaulB - 18 Mar 2018 at 9:30am |
Amos ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ontario Points: 1318 |
I bought a monofrrame Allis Chalmers plow from a fellow at Chatham, Ontario, clay loam soil. He pulled it with a 200, told me you should not plow fast 4 to 4.5 mph is best. I pulled the same plow with a 8030 and my 200. The 200 needed weight, he told me that too, but he was right at 4.4 mph that plow does the best job of any plow I have ever used.
oh yeah, 6 x 18's My Dad had the same series of plow with 8 furrows behind a 210, in alfalfa, well you used a lower gear and it should have had weights on the front yes...
Leon B MO ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2186 |
I had a 200 with fluid filled 20.8x34's., and a full rack of front weight's with an AC 5-16 semi-mounted plow back in the late 80's. In the bottom ground, the 200 would walk the dog in 3rd low. On the clay hills, the 200 and the driver had it's hand's full. Power was not a problem in 2nd high, keeping the front tires on the ground was a trick, the more the traction booster raised the lift arms, the higher the front end went. I hate to say it but but the higher the front end got the more I liked it. Pure power, thanks for the memory.
Leon B MO
Make sure the front pivot is not froze on that IH PLOW. IF it is, run. A lot of them are froze if they set out side for long. MACK
Thanks for all the advice. I did check the pin and the hitch does pivot.
The dealer with plow says it is set up for 30" rows and that I should have 36" from c/l hitch to c/l tires. I measured 39" on the 200.
Will the plow adjust to get the 36"?
Lars(wi) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Permian Basin Points: 8047 |
you need to measure from the center of the pto shaft, to the side wall of the drive tires. we had uor plow tractors set for 38 inch rows, even tho those tractors never were used for planting or cultivating/spraying. Both sides should be set the same distance, and your front axles should be set so the tire side walls dont rub the furrow wall.
steve fischer ![]() Orange Level ![]() Joined: 11 Jul 2011 Location: sleepy eye mn Points: 992 |
use to pull a oliver 588 4x20 behind a 190xt sand ground 6 gear and alfalfa 3 rd
caledonian ![]() Silver Level Access ![]() ![]() Joined: 02 Apr 2016 Location: Nebraska Points: 470 |
We had a 2000 monoframe 4x16 plow with harrow behind a 180 diesel in eastern Nebr soil. Worked good. Loved running that outfit.
180Puller ![]() Silver Level Access ![]() Joined: 15 Jan 2011 Location: Missouri Points: 226 |
Dad bought a new AC 200 in 1973....We always pulled 5x16's with it in fairly easy plowing ground....Go 10 miles north and 4x16's would be a load...A neighbor once pulled a 6x14 Oliver trail plow with a 190 XT and duals....
HaroldOmaha ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Omaha Points: 862 |
We were plowing some clay ground and one fella had a big JD tractor and one of those IH plows Mack was talking about. He hit a rock and tripped a bottom. We used levers and jacks and could not get it reset. It was rusted so bad it would not move.
d21_man ![]() Bronze Level ![]() ![]() Joined: 26 Jul 2015 Location: Rossville, IN Points: 31 |
Years ago we pulled a semi-mounted JD 4-16 with our 180 that was ballasted and weighted along with a JD 6-16 with our 7000 that was ballasted and weighted. Had no trouble in various northern Indiana soil types. However, a friend of ours seemed to struggle a bit pulling a 5-16 with his 190XT...as the guys mentioned, don't think he had it set up right.
allisbred ![]() Orange Level Access ![]() Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
You should be good with 4-18" and deep in clay with your 200 in 2nd high or 3rd low. Ours just plays them w/38 x 18.4's and weighted 3/4 throttle(does not thrash the engine)
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34310 |
One of the local 'boys' was out plowing clay ground with his 966 and 4x16 710 plow and was having a hard time plowing up a 40 acre patch, he went up to the feed mill and met another farmer and told him of his troubles and Mike said your plow isn't set up right... He would be down after dinner with his outfit... Mike would have taken his 1266 but that was hooked to something else... so he rolled in with his 856 without duals on (was his pulling tractor) and his 6X18 720 on-land IH plow... and dropped the plow in the ground and came smoking up to where the 966 was laboring along. They stopped and Murrey looked at the 6x18 behind the 856 and said you can't be pulling that very deep... took out the tape measure and Mike was plowing 8" deep, Murrey was 7"... Mike and Murrey spent about an hour trying to get that 4X16 to plow decent and finally Mike told him to go home and he would finish the field... couple hours later he was done. Murrey traded the plow off and got a 720 4x16 and it pulled much easier.
Sometimes its the design of the molboards, sometimes its the steel in them. Dad had 3x14 sc AC plow that had the full plow share and had the old blacksmith put a new edge on them... put them on and went to the field and the old WD could not pull the plow... took the shares back and told the blacksmith he couldn't pull them and the smithie said oh I made them too hard and reheated and re-tempered them and then they slid through the ground like they should have. |
Bob I pull that plow with my 200, heavy dirt, fluid in the rear and no front weights. No problem. Does it pull hard? Yes!!
Edited by HD6GTOM - 19 Mar 2018 at 10:18am |
aras ![]() Orange Level ![]() Joined: 28 Jul 2011 Location: Weston, WI Points: 665 |
It's interesting to hear peoples opinions of plows. Mine is for cornstalks a IH is okay in sod they are rough. We only use a Kverneland. Parts may be a bit more but the field is smooth when you're done plowing. Pulled a 4-16 with a 180 and then a 5-16 with a 200 then a 5-22 with a 8050
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5227 |
My brothers 190XT with rear weights pulls my 4x16 semi mount AC plow very well in 2nd HI(or 4th) to be correct by the decal. Was turning over pasture field sod that had not had a plow in it for 15 years. Will be using my XT this year on plow day on March 31st. Fluid filled rears.
Ky.Allis ![]() Orange Level ![]() ![]() Joined: 31 Jan 2010 Location: Kentucky Points: 1030 |
This has been an interesting thread so I will add my $.02 worth. I used to pull 4x16 AC monoframe plow with Midwest buster bar harrow with my (96Hp) 200 with front weights and loaded rears. It did fine but it was a load when plowing at 8-10". I remember threads on here in the past where guys swear their (54Hp) D-17's pull 3 and 4 bottom plows with ease. I'm confused !!!!
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12161 |
I heard that! There ain't much more confusing in the world than reading through a who pulled what with what plowing thread. We used to pull a 3 -16 fully integral JD plow with a Massey 165 and a lot of the time had a "sod buster" hitched to it as well, which was like a small offset sheeps foot. I wouldn't say it pulled it easily by any means, but that's what we did. Upgraded tractors and it TOYED with that 3-16, and we always wanted a semi mount any way, so we bought 4-16 JD semi mount and pulled it. The tractor was a JD 2640. Fluid in the rears, 1 dual, weighted for bear up front, and it pulled it pretty good most of the time, but our areas of clay, hills, and alfalfa ground would give it a workout. We used that for a lot of years. *edit* I left out a chapter. The first 4-16 semi mount was an Allis monoframe, and I loved that plow. Best we ever did! Pulled easier than the JD we got next. Bought the Allis 7045, over double the horsepower of the 2640, obviously toyed with the little 4-16, so we bought a 6 bottom variable width, and I'm all over the map trying to pull that thing. So, I'm confused too! ![]() ![]() Edited by Tbone95 - 20 Mar 2018 at 10:40am |
Speed and depth always seemed to increase as HP levels went up. When I plowed with a WD45 and a 3-16's 70 series plow in sod, I'm sure it was never more than 5 inches deep and at a 3 1/2 MPH rated speed (no load speed). So, 3 bottoms X 5 inches deep is 15. Now, Take a 190 XT or 200 with 5- 16" bottoms X 7 inches deep you get 35, AND you are pulling it faster than 3 1/2 MPH....closer to 4 1/2 MPH.
'zactly Doc. The guys above talking about how many inches wide the cut is.....That's only 1/2 the story, depth and speed being the other half.
FWIW, I've been trying to set an 8 inch depth on the "new" plow, which is about the same as I've been doing. |
It all goes down to the type of soil you are plowing, the depth you are plowing, and the speed that you are pulling the plow....As I have mentioned I live in an area of easy plowing ground thats kind of sandy with a few clay spots....All WD-45's pulled 3 bottoms and all D-17's pulled 4 bottoms...All 190 XT's and 200's pulled 5 bottoms....My 7040 and 7060 AC's played with my 6x16 AC plow at 8-9" depth..I had an 856 IH that had no problem with my 6x16 plow but it had 150 horses from lots of modifications for tractor pulling..When the new 220's came out our local dealer had a plowing demonstration and the 220 was pulling 7x16's with ease..I made one round with it.. About 6-10 miles north of me is a small area of real heavy black gumbo soil that plows hard..I never plowed in it but I'll guarantee that you will take one bottom off from my soil to that soil and you will still struggle....There are a great many soil types in this country and everyone of them plows differently....A 5 bottom tractor in one area is barely a 4 bottom tractor in another area..
Edited by 180Puller - 20 Mar 2018 at 12:50pm |
