d15 power steering leak, internal?
trevorno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trevorno Quote  Post ReplyReply Direct Link To This Post Topic: d15 power steering leak, internal?
    Posted: 26 Feb 2018 at 2:12pm
As it says, I have a d15 that leaks ps fluid. I've added fluid a lot lately but it always reverts back to 'manual steering mode'.  I cant find where its leaking on the ground, is there a way it could be leaking internally? Where should I start looking?
Edited by trevorno - 26 Feb 2018 at 3:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 2:28pm
It's either leaking on the ground or the engine is waaay overfull on oil. Never seen one leak into the engine, so you're on your own.
Post Options Post Options   Thanks (0) Thanks(0)   Quote trevorno Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 2:41pm
Can it leak into the engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote trevorno Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 2:46pm
Or are you implying i may be accidentally overfilling the engine? I'm not, but I dont mind the question.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 3:27pm
Hi Trevorno.
When was the last time that you checked your engine oil dipstick?
Like Doc, I haven't heard of power steering fluid leaking into the engine.
How blessed we are by HIS GRACE!
Post Options Post Options   Thanks (0) Thanks(0)   Quote trevorno Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 3:30pm
I checked it two days ago. It was a little overfull. I just fixed a stuck carb float so I think it's gas that's causing it to be too full. I need to change the oil anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 4:20pm
Look under the front of the tractor to see any fresh oil leaking.  Clean up any dirty areas first if need be.  Doubtful that it would leak into the engine.  Also check the lines, some might be loose.
*DougW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote *DougW Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 5:48pm
Is it a narrow front and leaking into the pedastal??????
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 7:17am
When you go to fill it up next time, use brake fluid. If it's just o-rings that's gotten hard the brake fluid will soften them and there's a good chance they'll soften up and swell and stop leaking. Try dropping an o-ring into some brake fluid and watch it swell up over a few days time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote trevorno Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 10:57am
No, wide front end.
