AC D-19 turbo diesel versus JD 4010 diesel |
Post Reply | Page 123> |
Author | ||
Orange Level Access Joined: 12 Sep 2009 Points: 19649 |
Posted: 09 Dec 2017 at 6:45pm |
September of 1960 the new JD 4010 was tested at Nebraska. The AC D-19 turbo diesel wasn't tested until April of 1962. The 4010 had a direct injection design engine with an oil bath air cleaner. The 4010 had a "live" and fully independent 540/1000 RPM PTO. It also had a "live" 18 GPM hydraulic pump, hydraulic "wet" brakes, an 8-speed partial synchronized helical gear transmission, fingertip hydrostatic power steering and a high platform with an easily adjusted super nice seat. The 4010 tractor was equipped with a 3-point hitch. The D-19 had a turbocharged energy-cell designed engine with a dry-type air cleaner. The manually engaged 540 RPM only PTO required use of the Power-Director clutch to be considered "live". The 5 GPM non-live hydraulic pump plus an 8 GPM power assisted mechanical steering pump yielded a 13 GPM total hydraulic system. The brakes were mechanical. The oil cooled Power-Director hand clutch allowed on-the-go shifting and ground speed control for PTO work. Transmission was a constant mesh non-synchronized helical gear design with a total of 8-speeds. The operator sat very low and the seat was just OK. The Traction Booster system was coupled to the snap-coupler style hitch, which performed well with mounted and semi-mounted implements. |
Sponsored Links | ||
exSW
Orange Level Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Still rather havea D19. 4010 was just a test mule for the 4020.
HD6GTOM
I was in the farm fuel business from 1973 to the mid 1980's. I saw a few D19's being used. I saw quite a few 4010's. When the company I was leased to bought my fleet of trucks in the mid 80's I still saw most of the D19's being used but most of the 4010's were long since traded off.
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8174 |
Thanks Drallis for that. What prompted you to share with us,
Only D-19 story I have is I heard how my grandfather had one new on the lot and my great uncle used it a lot on the farm and wanted to trade his D-17 in on it but back then diesels weren't real popular around here and gramp leaned him away instead of to it |
1terrygladys
Silver Level Joined: 03 Oct 2013 Location: SW Iowa Points: 258 |
How did they compare in horsepower and fuel efficiency?
Terry
WD-45, WD, 35 Unstyled WC, 36 Unstyled WC, SC Disk, JD 4430D, JD 4010D, JD B, Iowa pastor & disciple of Jesus Christ
Deere at 84 max HP uses 5.6 GPH and 15.67 HPhrs per gal. A-C at 67 max HP uses 5.2 GPH and 13.35 HPhrs per gal. At PTO speeds Deere at 77 HP uses 4.9 GPH and A-C is 65 HP and uses 4.8 GPH. Deere wins in efficiency hands down with the direct injection engine.
PeteMN
Bronze Level Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 192 |
Don't know anything about the JD engine, but the Allis engine (like quite a few other brands of diesel engines of that time) lacked enough cooling capacity in the block. It was great on fuel, but if it wasn't properly warmed up before working it hard and cooled down after working it hard, then the engine would develop problems.
JayIN
Orange Level Joined: 18 Dec 2009 Location: SE/IN Points: 1982 |
What I have learned from actual personal experience is that the owner of the 4010 was probably a arrogant a-hole. Especially more prevelant in todays modern times.
NEVER green
Orange Level Access Joined: 28 Feb 2013 Location: MN. Points: 6626 |
I concur!!!!!! We got a saying round here.... green and greedy. |
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4446 |
If someone was going to give me my choice of either, I'd have to say I'd take the 4010. After having run both for more hours than I care to recall, I find the 4010 to be much more comfortable for me than a D19 . The 4010 is a far superior tractor to be in the seat of all day on and has truly modern features. Now if you ask me weather I'd take a 410 over a 190XT diesel, now that will have a completely different answer, I'd take the 190XT without even blinking.
tomstractorsandtoys
Orange Level Access Joined: 11 Feb 2015 Location: wi Points: 515 |
Spend a long day on both tractors and the 4010 wins. Much better seat,steering and a nicer operaters platform. 60 years latter you can buy 2 D19's for less than one 4010 and in my area there are still lots of 4010's in use and rarely a D19. My grandfather had a new D19 for one year before trading it on a 190XT. He almost bought a 4020 but the Deere dealer was not excited about trading the D19. Dad thought sure he was going to get a 4020 and was not happy when the XT came home. He went and bought a new 4020 and a week later bought a second used one. On my grandfathers 19 they could never get the draft control to work right. He had a four bottom semi-mount plow and when he lowered it the front would go to deep before the draft control would take over. Dealer tried working on it and changed a good many parts but it never was right. My grandfather really liked the XT. He bought it with a six bottom AC hyd reset plow. The plow did not work very good in the limestone rock he farmed and AC sent engineers to his farm three different falls to make improvements to it. They ended up adding a second hyd. accumilater to it so if all six bottoms tripped the oil could flow fast enough without breaking something. They went to alot of tractor pulls and Dad's 4020 always beat the XT but in the field the 4020 could not pull the six bottom plow without running hot. Sorry about getting off topic. Tom
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8053 |
neighbors bought a new D19 gas and traded it a year later on 190 diesel.Don't know the year.Dad said the 19 was a gas hog. I always thought it was a case of 190's not yet released when they bought the D19,but don't have dates and time lines.
bigal121892
Orange Level Joined: 05 Jan 2010 Location: Nebraska Points: 756 |
Really? My dad had a 4010, and you don’t even know him. Biggest A-hole in our community was the guy that had all AC’s, constantly trying to rent everyone’s ground. Edited by bigal121892 - 10 Dec 2017 at 10:31am |
SteveMaskey(MO)
Orange Level Joined: 11 Sep 2009 Location: Wellsville, MO Points: 591 |
I am a true AC fan grew up on them and still have and use them, but the Dr's statement is right on. JD was way ahead of AC and my opinion is that they never caught up till the 8000 series by then it was to late. I have 2 180’s with loaders that I like real well and always wished they would have made one with a FWA
Arcs and Sparks
Bronze Level Joined: 28 Dec 2015 Location: Ontario Points: 116 |
My uncle bought a new D-19 diesel from a local dealer who had given him a sunshine enema on the performance it would deliver. My uncle had a custom silo filling business and put the D-19 on a 2 row Gehl harvester. It simply was unequal to the task and it had repetitive head gasket failures ( 3 that I remember and I was quite young at the time ). It was a disappointment considering that it was a brand new machine. It did not stay in the role it was bought for very long. It was replaced by a Cockshutt 1655 which was married to the harvester for 20 years. I wish I had his D-19 now to restore. The 1655 went to my cousin when my uncle died 10 years ago. He drove it home and it has never moved since. He also passed and his wife is content to let it sit there and rot. There should be a law against that
victoryallis
Orange Level Joined: 15 Apr 2010 Location: Ludington mi Points: 2865 |
4020 has to be the most overrated tractor in history. I helped someone with hay when I was in high school and college I HATED that tractor with a passion. Same person is amaized what my 6080's will do compared to his 4020.
CrestonM
Orange Level Joined: 08 Sep 2014 Location: Oklahoma Points: 8361 |
One of my grandpas was that way with his 4020. The other grandpa has a 4020 as well, but is so nice, you'd think he was an Allis guy! (Well, he is...kinda) I for one really do like the late model 4020s. 4010s and early 4020s are alright, but the later 4020s have some nice improvements with the PTO shift linkage, and console hydraulic controls. Only thing I'd change about it is maybe include a tilt steering wheel, but they're fine like they are. I get a chill every time I hear grandpa rev his 1972 4020 diesel. LOTS of priceless memories made with him on that tractor. He bought the tractor new in '72, and the only problem he ever had with it was it overheated really bad the first couple years he had it. He didn't know what the problem was, and neither did the dealer. They replaced water pumps, radiators, even rebuilt the engine 2 times! Nothing fixed anything right away, but eventually it just quit overheating and has ran perfectly ever since. No one knows how/why.
Edited by CrestonM - 10 Dec 2017 at 12:52pm |
AC7060IL
Orange Level Joined: 19 Aug 2012 Location: central IL Points: 3214 |
Some growth issues should be expected as both the AC D19 turboed diesel & the JD 4010's 6 cylinder designs were new features for each company. I operated an AC D19 gas & was disappointed in its lack of power & it's high gasoline usage. I never operated its diesel version, but was always under the impression that AC's engineers pushed the turbo in an 11th hour resolve to boost HP... So it probably lacked testing?
JD's newer 4 & 6 cylinder engine designs had issues too. Until JD learned how to remove casting sand from its large cylinder engine blocks, they were replacing every tractor's water pump in the first year of production. Edited by AC7060IL - 10 Dec 2017 at 12:48pm |
AC7060IL
I have owned a 1961 JD3010 diesel for 18 years & accumulated some 4000+ hours on it. It starts better at colder temps, is very fuel efficient, & is handy for most smaller jobs. Over the years, I've replaced clutch, hydraulic pump, fuel pump, Trans top shaft, Trans synchronizers, 3pt load shaft, tires, & paint.
Ed (Ont)
Orange Level Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1228 |
Too bad to spoil a good informative thread with this kind of thoughtless comment. Hopefully we can judge our members or others on something other than tractor color!!!!!!!!!! I'm sure this was not the intent of the thread. |
Gerald J.
In the JD 4010 and 4020 there were so many changes between the first one in 1960 to the last one in 1974 that there should have been at least half a dozen model numbers used. The 4010 and pre side console 4020 ('64 to '68) are similar enough they share parts book and shop manual. There at least three versions of the pre side console 4020 operators manual because of changes in the electrical controls and wiring harnesses. And they had a hydraulic system that had a common mode of failure as the check valve at the charge pump in the transmission failed and then drained the up top and front cooler/reservoir that the main hydraulic pump depended on if the transmission wasn't turning. With steering and brakes all by hydraulics that was a serious problem. I have a web page about fixing it. http://www.geraldj.networkiowa.com/4020si.htm
They changed so much in the hydraulics of the side console tractor that it doesn't have that problem and doesn't share parts, parts book, or operator's manuals. The side console tractor engine is significantly different in all details too. My '68 gas 4020 is considered a gas hog. According to Nebraska tractor tests it is not fuel efficient but there was a similar vintage IH 686 gas hydrostat that was worse. The 4010 and early 4020 gas used either a Zenith carb or an odd Marvel-Shebler that used a vacuum diaphragm for the accelerator pump. I think the gas AC of that era and size used the same two carbs. The MS was so hard to tune and work on that a JD service bulletin I have says "If you can't tune it, install the Zenith." The first year I had my 4020 it used 4 times the gas that my MF-135 took doing the same acres. It smoked like and IH diesel. I found a bunch of problems like the choke not opening because the cable sheath wasn't anchored near the carburetor and I got it down to only twice the MF135 fuel but it did the tillage in a lot less time with bigger implements. As for the 6 cylinder engines, Oliver had gone that route long before the 4010 or AC. The 4020 synchro range transmission shifter is very odd and takes learning to get along with it. It is not logical at all. The Power Shift was more logical and less fuel efficient. Gerald J. |
exSW
Amen. Huge difference between 4010 and late 4020PS. 4010 was just a good idea not well implemented. Late 4020's are still great tractors.
randy
Orange Level Joined: 12 Sep 2009 Location: Illinois Points: 1177 |
Ed, I could have not put it any better! I agree 100%
CrestonM
Wait, the Power Shift is less fuel efficient? But yes, the synchro-range is pretty funny. When my "good" grandpa bought his 4020 in 1972, his father-in-law (my great-grandpa) liked the tractor, but never would drive it because he couldn't figure out the shift pattern. (He was 72 at the time) He never did figure out the pattern, and he died in 1995. Instead, he stuck to the 930 Case they had. He liked it because he could pop it in gear and go. (The only guy on the farm who liked the 930). When I was growing up, I was completely mind boggled by that shift pattern, and for most of my childhood I couldn't shift it either. Then one day it finally clicked! I've since memorized the shift pattern, which was kinda necessary. My "bad" grandpa had a early model 4020 LPG, and it was a piece of trash (kinda like him, but that's another story) Sat outside its whole life, almost nothing worked right, etc. The shift pattern decal was completely gone off the dash, so when I'd run it, I'd have to shut my eyes and envision the pattern decal off my other grandpa's 4020. Once I got it down, it was actually kinda fun. Especially in school when kids brag about knowing "how to drive a stick shift car" and "memorizing the pattern". I'd usually shut them up by showing them a photo of a 4020 shift pattern. Lol |
180Puller
Silver Level Access Joined: 15 Jan 2011 Location: Missouri Points: 226 |
I like D-19's but they never had a great reputation in my area..The few that were sold new were all traded off in just a few years for other colors..
In late 1961 a farmer from 35 miles away that farmed 600 acres there bought 520 acres beside us..He hauled over (2) WD-45's and a D-17 diesel to farm the 520 acres in 1962...In late 1962 he traded a WD-45 for a new D-19 gas....He soon found out that the D-17 diesel would way out work it so after owning it less than one year he traded it for a new 4010 JD diesel...He liked the 4010 so good that when the 4020 JD's came out that he traded the D-17 for a new 4020 JD.. He disliked the D-19 because it drank so much fuel and the D-17 would pass it when both were pulling a 4 bottom plow..He had 5 bottom plows on both the 4010 and 4020 and in our soil they pulled them nicely..Dad did lots of plowing for him with the 4010.. About 15 years ago a neighbor 4 miles to the south had a sale and his dandy D-19 diesel only sold for $1300...I sure do wish that I had bought it..
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50739 |
My grandfather had a brand new D-19, many folks came to see it, when he bought it. Problems we mainly had with it were mainly camshaft related, in the motor. May have been his excessive use of ether, as cold start aid, too. I remember once, when grinding corn, fer over a half day, he shut it down, and about 5 minutes after we heard this huge BOOM! Went out to look, lower hose had blown like a tire, do there may be some merit in the cooling theory. It also liked to blow head gaskets (maybe ether, again). Had a Hyd cam follower grenade in the hyd compartment, once, don't know the cause, but the effect was me, on my back, under the old shade tree, with a roll of emory cloth, while someone else cranked the starter, to smooth out the hyd cam lobe, that got tore up, when the follower blew up.
All in all it was a reasonably good tractor, not like the souped up 6000 ford, a neighbor had. The 4 bottom SC 16" plow that came with it, was another story. It was really too big for most of the rolling terrain, we have on the farm. Seems to me, Correct TB adjustment was an elusive goal, that was never met. In the bottoms, it always dug in deep, and got you stuck, on ridgetops, or knobs, front or back allus seemed to be in the air! We bought a used 3 bottom JD trailer type plow, that I later found out the D-15II pulls easily.
Gerald J.
The 4010 never had the Power Shift transmission, only the Synchro Range but it had 3 reverse gears where the 4020 SR had only 2 reverse gears. The third one JD considered to be too fast to be safe. Its not hard to modify the shift linkage to get that third speedy reverse gear.
Side console 4020 still bring a higher price on the used tractor market than early 4020 or 4010. During the side console 4020 era, JD brought out a 4000 that was to be a 4020 with lighter drive train and cheaper cost, but did offer it with the expensive Power Shift transmission. I saw one at a JD gathering for sale a gas 4000 with PS for over $14,000 asking price and it was grubby. There weren't many of those made, only 9. Gerald J. |
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7972 |
Only had 1 D19 around here in my early days, the Mebeur boys did some heavy duty tractor pulling with it, always done good too; a 4010 is a nice tractor, the shifter is a good idea and isn't that hard to figure out , very simple actually,,
darrel in ND
Orange Level Joined: 22 Nov 2009 Location: Hebron, ND Points: 8595 |
My very first Allis Chalmers tractor was a D19 gas (not new, obviously, until I got done restoring it). I loved that tractor, and still do, enough that it turned me into a die hard allis man. And that, after in my growing up days, being told daily that John Deeres were the holy grail of tractors. Darrel
don't know when or what models you could get diff lok,but that was one thing JD had that sold a lot of tractors in the black dirt up north that got fall plowed,or so a mechanic told me from that color and era.
