7010 PD Hi-Lo Cable Adjustment? |
Roscoe62
Joined: 22 Aug 2014 Location: Louisville Points: 145 |
Topic: 7010 PD Hi-Lo Cable Adjustment?Posted: 13 May 2017 at 10:25am |
I was having problems getting the trans into low, only after multiple shifts between hi and lo.
So I put on a new SMALL shifter cable today, and it still won't go into low. The lever goes into position, but the trans does not. After I put the new cable on, the lever would not go into the high position until I lengthened the LARGE shifter cable by one turn. Is there a procedure somewhere for this? thanks, Roscoe Edited by Roscoe62 - 13 May 2017 at 11:01am |
Roscoe62
Posted: 13 May 2017 at 1:05pm |
It sometimes will go in low, sometimes won't. I am clueless what to do next, if anyone has done this before?
Thanks, Roscoe.
DougG
Posted: 13 May 2017 at 1:46pm |
Sounds like something is moving maybe where the cable is attached to?Just a guess, I have no experience with these but want to learn , please post what the fix was when you get it
grinder220
Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2375 |
Posted: 13 May 2017 at 2:23pm |
My 7040 ps is the same way,put new cables on and didn't help. I noticed the park lock doesn't come out completely on its own,cable sticks a little so maybe that has something to do with it. Thats the only cable I didn't replace yet.
MACK
Posted: 13 May 2017 at 9:59pm |
Take the side cover off the console, down at floor there is a hole in linkage where you can hook a spring. AGCO 70514773 bailer spring is just right to move linkage for better shifting. MACK
Roscoe62
Posted: 14 May 2017 at 6:12am |
Thanks MACK, I was hoping you would see this and reply.
I put it all back together since I had to start mowing yesterday. I will take the cover back off after church and if I can't figure out what you mean, I will post back.
One good thing since I had it all apart, I did weld the brace to the PTO cable bracket, as Doc said, to stiffen it up and allow me to take it out of gear. That worked like a charm. I also took the slop out of the transmission foot clutch cable by replacing the worn, sloppy ball end with a good one. Now my trans brake works again. It sure is rough not having Lo range though. 1 Hi-Hi is too slow and 2 Hi-Lo is too fast for mowing rough ground. Can't wait to get my Lo range back again. Thanks again. Roscoe. |
Roscoe62
Posted: 14 May 2017 at 7:07am |
Couldn't wait, so I did it this morning. Unbelievable. Works first time, every time.
I just used a heavy spring in the spare parts bin. Photos below: Thanks, thanks! ![]() |
Roscoe62
Posted: 14 May 2017 at 7:12am |
Close up:
DougG
Posted: 14 May 2017 at 7:16am |
Perfect!
