pull start a 180 diesel
joshjohndeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Topic: pull start a 180 diesel
    Posted: 27 Jun 2010 at 4:42pm
has anyone ever been able to pump up the power director clutch sum how so that it engages, that way the tractor could try to be pull started?  i am a john deere mechanic and we can pump off the park brake with a porta power i was just wondering if i could do the same thing by pumping the power director either on to the high side or low side so that i can pull start the engine as to break it loose possibly or just try to start it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 5:50pm
As far as I am aware, when the engine is off there is no hydraulic pressure to activate the clutch packs section of the PD, mine will not hold when parked to leave it sit in gear without having the brake locked engaged or the bucket loader stuck into soft ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 7:57pm
what im trying to do is lock the power director in manually with a porta power or something so that i could put the transmission in gear and pull start the tractor.  i am aware that the power director will not engage without hydraulic power or a running engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 8:01pm
Won't work....too much leakage around seals.....you'd have to keep pumping it up continuously and never exceed 400-500 psi or it could split the clutch itself. Also if you had the tranny in say 3rd gear and pulled it 15 mph the PD clutch could explode from over RPM's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 8:12pm
i was gonna hook up another tractor to it and run off the scv's on it to power up the pd while pull starting it. my problem is the starter wont spin th motor fast enough or good enough to even prime the fuel system let alone start the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 8:14pm
and i have tried 3 different new starters and none of them start the tractor they will spin it 3 revolutions and then stall out i can let off the starter button then it will turn 3 more revolutions.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 8:39pm
It sounds like you have an electrical problem or an engine about to lock up (I doubt the latter).  Check your ground connections and the battery condition.  What is your voltage dropping to when you crank the starter over?  It shouldn't fall below 10 volts.  It should be holding around 12.5 after being fully charged.  It does take a while to bleed the fuel system on these engines.  I would use the plunger pump to bleed as much as you can into the pump (I want to think there is a plug on the pump that can be removed to let out air, but can't remember right off, DrAllis will probably be able to correct/confirm this).  Then crack the injector lines and once you get fuel and no air coming out of one, tighten it off and go again, the next one should be coming up.  I have found the engine will usually run under it's own power after 2 or 3 of the injectors have been bled, then you can go ahead and bleed the rest while it is idling under its own power.  What you are describing is not normal, I would take your battery in to get tested first, and if that checks alright, your starter, all after cleaning the terminals.  You could have some corrosion up under some insulation in one of your battery cables.  I hope this helps you get going.
Hurst
1979 Allis Chalmers 7000
5800 Hours
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 8:39pm
you may be able to try air pressure
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 8:44pm
i dont think u read the message earlier it wont crank more than 3 revolutions, it has a new starter, 2 new batterys, all new cables my voltage drops to 10.97 on my multimeter, and my batterys jump right back to 12.7 vdc within a few seconds after i let off the starter button. i made sure my ground point was cleaned and i buffed the mating surface that my starter bolts too. and i noticed my positive cable gets hot real quick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 8:47pm
well i was wondering about the air pressure thing also because thats how we test the 2 speed clutches on 30, 40, 50, and 55 series tractors
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 9:00pm
any chance you are building hydraulic pressure ? valves in neutral?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 9:08pm
I wouldn't go pull starting that thing, even if you could.  There's something not right and you risk doing more damage than good.  Is this engine a fresh rebuild or something?  It sure sounds like something is locking up on you and that's why you only get 3 turns.  Pull starting it, if possible, would just probably cause some damage.  Can you pull the injectors and try to spin it over with them out (so you have no compression).  That will give us a better idea of where the problem lies.  Make sure everything is in neutral as suggested above also, just in case you are building hydraulic pressure that fast.
Hurst
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 9:43pm
I agree with Hurst, sounds like something is dragging it down. My guess would also be hydraulic. If it were mechanical, I would expect it to not turn at all. Is there any way to unload or remove the hydraulic pump and then see how it cranks?
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 8:33am
Sounds pretty simple to me, figure out why the engine does not turn over properly and correct the problem. The engine was designed to be started with the starter motor, all tractors operate this way, something is not right,fix the problem
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 9:41am
I would try pulling then have someone pump the porta power.  The power director should engage with a couple pumps then the engine should spin the hydraulic pump after that to keep the power director engaged.
Note: this advice is worth what you paid for it.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 10:15am
Do not try to pull start!  Large cast housings/PD clutches have exploded when trying to do this.  The last time I knew of one the situation ended with extended hospital stays, many surgeries, and lawsuits.  The only winners were the lawyers.  Dr. Allis gave you good advice; I'd follow it.
Brian F(IL)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 11:12am
Yeah I agree. Do not pull it 15 mph try 2 mph with the tranny in 4th gear and the PD lever in high.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 11:37am
I don't think it's a matter of finding a way of pull starting the tractor.  It's the fact that something is binding and that problem needs to be solved before you go trying to yank on the engine.  What ever it is needs to be fixed and pull starting won't do anything but cause more damage, that is all assuming you would be able to build up pressure on the clutch plates in the PD.
Hurst
5800 Hours
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 12:32pm
There is a "rest of the story" here, Josh you need to figure why it turns over so hard.  Pulling to start isnt gonna work, even if you did lock up the clutch   and you dont blow  it up, something else is wrong and it could leave a big hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 6:31pm
first of all hurst and skipwelte can go and poor word choice themslves, i have been a mechanic for many years and am smart enough to know i have something wrong.  second of all i have pulled the hydraulic pump off the engine and it still has this problem, the reason why im trying to spin the motor is because i think i have surface rust on the cylinder walls. the tractor had been sitting for about 6 years and was partially outside.  the engine only has 3045 hours on it so im ruling out the idea of bottom end  engine failure because when i changed the engine oil it had neither fuel or water in it and no filings whatsoever.  my next point is who in the hell would be stupid enough to pull something at 15 mph anyways i just want to pull it down my drive way at like 2 or 3 mph and spin the motor and get things lubed up again.  i have sprayed yield and free-all down the intake to try to lube the cylinders up and dissolve the rust. i have pulled the valve cover and all my valves are opening and closing properly, i have not pulled the injectors yet as i ran out of time to work on it this weekend.  i came to this site hoping to get some good old fashioned know how and advice not stupid people and stupid comments. i do appreciate the sensible advice i have recieved though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 6:33pm
oh and by the way chris/ct u can go fall off a cliff with your dumb comment.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 6:34pm
I guess if you already knew the answer, why did you ask the question?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 6:42pm
Josh, There are many people here that ask questions and many that give their best idea of an answer. Skip and Hurst and Chris all contribute to this page. No one on this side of the computer can know your abilities so most of the time if advice is given, there are also words of caution given just in case the asking party isn't a qualified mechanic. Your smart ash comments will get you nothing and I believe you owe at least 3 people an apology.  Just my 2 cents worth. Charlie
Edited by CTuckerNWIL - 28 Jun 2010 at 6:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 7:05pm
I'll just assume you're having a bad day (I've had plenty of them working on tractors) and put the bad part of that post behind me and continue to try to help you with some ideas.  I've been inside a 301 and there are people on here who have been inside more of them than I have probably seen in my life.  Can you give us a little more details on the tractor's condition after sitting.  Did you find the tractor stuck and you are starting to get it loosened up?  If you can, see if a friend will lend you a bore scope so you can actually get a good look inside the cylinders without pulling the head (those head gaskets are around $100 a pop, so I would try this in case everything looks fine).  If not, I would strongly encourage pulling the head off, if for nothing else, a little bit of peace of mind.  While 3000 hours may not sound like much, it could have been plenty of time for the sleeves to have pitted from cavitation and dumped coolant into the crank case (like I said, I don't know how much history you have on this tractor, so if you know the tractor was running fine before parked, this is probably not an issue).  If that is a possibility, there very well could be problems in the bottom end in addition to the bad sleeves.  Again, that is just pure speculation knowing what I know about these motors (that they are very prone to cavitation).  Again, if you tell us what you do and don't know about this tractor's history, especially pertaining to the condition when it was parked and how you found it, that would be a big help.  If you think you have rust in the cylinders, at least get a scope down there and make sure the walls aren't pitted if not pull the head and check for any other problems.  Popping the pistons out to check that all the rings are in tact would be ideal, but that's getting pretty labor intensive and near the point of just OHing the motor.  Fill us in and we can try to give you some more ideas.  I am not trying to be condescending when I say don't pull start the tractor, I am saying that so you are not having to ask if anyone has a good used PD assembly.  I have been around several different brands of tractors that had similar set ups and every manual has stated they should never be tow started as doing so can result in serious injury or death along with damage to components.  I hope this is of some use to you and keep us filled in.
Hurst
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 7:13pm
i understand your point mr ctuckernwil, but if you looked at my opening statements of this post i stated i am a john deere technician. therefore some people should also have to apologize to me i gave the appreciative comment on the end of one of my previous posts that i appreciated the sensible advice i was given.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 7:30pm
I haven't seen anything on here that wasn't sensible advice.  We all try to look out for each other on here, meaning a lot of times people will post warnings on something that may seem blatantly obvious, but it's better than reading about someone in the obituary too...  I have learned a lot of what I know by reading the words of others on here and having them talk me through repairs, even when I have a service manual right in front of me.  However, that service manual doesn't lay out every little bit of knowledge out there for you, and there have been numerous times people on here have saved my butt by giving me advice to things I thought I already knew the answers to.  It's better for people to put everything they know that may in some way pertain to your problem than to just tell you only the little slice of the answer you are looking for and have you come back and ask why no one warned against the risks.  If you just want straight cut answers for your original post: No you cannot tow start a 180 without causing damage and/or injury.
Broadening from that a little more, if you suspect that the cylinder walls are rusty and that's the reason it's only going 3 turns before stopping, then all you will more than likely do by towing it (if you could tow it and make the engine turn over by some contraption) is break the rings.  Does it make sense where we are coming from now?  Maybe you will see our replies as a little more sensible.  I'm trying my hardest to be helpful.
Hurst
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 7:41pm
hurst i can turn the motor several times by hand with a prybar through the starter hole so no my motor is not stuck, as for the cavitation problem like i said earlier i neither have nor had any coolant water or fuel in the oil when i changed it.
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 8:25pm
Had a 190XT that a neighbor brought over here to "freshen up" for a tractor pull, he drove it over we changed the injectors and pump and put a bigger turbo on it went to start it and the starter refused to spin it fast enough to start, the batterys were poor, the cables a mess, so  put new batteries in it, made new cables would roll but not turn fast enough to make it fire, tried either, a booster still wouldnt roll and drew tons of juice, so I figured the starter was junk, it was hot, so removed a new starter from my own 190XT bolted it on the neighbors would roll it faster but still not fast enough to start, just couldnt understand it. I had the valve cover off  previously and adjusted the valves, and spun the engine over with a ratchet and socket it spun free, the guy drove the tractor here ran fine changed nothing that would have had anything to do with making it turn over so hard, finally gave up on it and told the neighbor he would miss the pull the tractor just refused to fire. 3 days later I decided to check it out more, put a wrench back on the dampner tried to turn it by hand like we had done in the past, and it was tight, dropped the pan and the #5 rod bearing had spun. It must have started to spin on the drive over here but the engine ran didnt knock or show any indication that it had a spun bearing, must have just started to spin as the tractor was shut down, and with the engine sitting cooling down having the bearing dry for a week while it was here must have been just enough of a brake on the crank as to not let it roll fast enough to fire, which in hindsight was a gift from god because had the tractor went to the track, more likely than not the engine would have gernaded. I know this isnt an answer to your direct question but I wonder if that isnt what you have going on. I have not seen a scope that is small enough to fit in the injector hole,we have tried, and if your rolling it by hand I would assume that the rust that may have been in the inside of the cylinder walls is knocked off, and if you have been squirting lube in there I would think by now the cylinders would be slippery enough to let the engine roll. Have had older WD45 that had rust in the cylinders but it would stop the revolution dead, and neither the crank or the starter could over come the rust spot till we removed the cylinder and honed out the rust, so I dont think that would be your problem. But much like the neighbors tractor, the last guy that had worked on the engine was a moron and pulling the engine apart yielded a weath of information on why this engine didnt run right, if you dont know the history of that tractor or why it was parked for so long, or who "tried" fixing it in the past you could have a bunch of issues lurking, hope this helps and I hope you get to the bottom of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 8:28pm
Does it matter whether or not you have the clutch pushed in as to how many times it will turn over with the starter before stopping?  Any chance you have access to an oil purger/charger.  If it hasn't started in 6 years, I am thinking your bearings in the engine are dry and just binding after turning over at the starter speed a few revolutions.  I have seen this happen on an engine that sat for a while before (not a 301, but a gas engine) from not having oil in the bearings.  If you don't have access to this, I would pull the injectors and turn it over without compression and also try to find a gallery plug and poor clean oil into this to get that oil system primed and oil to the bearings.  The way you describe it makes me think the bottom end is binding or something in the transmission is binding (which is why I am wondering if pushing the clutch in makes any difference).
Hurst
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 8:54pm
i can push in the clutch but im not 100% sure it is disconnecting becasue someone had stolen the starter from the tractor back when copper prices were high and u know the rest.  the reason im not sure if it is disconnecting is because im sure the clutch got some moisture in it with an open starter hole to the flywheel.  the lady i bought it froms husband finally died 2 years ago after being bed ridden since he parked the tractor so i cant get much insite on the whole thing.
This page was generated in 0.219 seconds.
