coolant filter |
orangereborn
Topic: coolant filterPosted: 24 May 2017 at 1:00am |
Head scratchier. 200 filter. Not sure what they were trying to accomplish.
shameless dude
Posted: 24 May 2017 at 3:41am |
that's funny right there! prolly had it worked on at a green dealership?
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1802 |
Posted: 24 May 2017 at 5:00am |
That's one heck of a puzzle!
DougS
Posted: 24 May 2017 at 5:16am |
It's called a bypass filter. It allows the water to bypass everything. :)
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4903 |
Posted: 24 May 2017 at 6:05am |
Well at least they were changing the filter regularly!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
Posted: 24 May 2017 at 6:57am |
Another good reason to just use treated antifreeze instead of a coolant filter.
ocharry
Posted: 24 May 2017 at 9:14am |
so what are we accomplishing here??? there are no valves to make the water flow through the filter,,,i doubt it even gets water through it,,,,the lines bypass it,,,,lol,,,,i aint seeing it
ocharry
allisrutledge
Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1361 |
Posted: 24 May 2017 at 11:27am |
looks to me like an employee doing exactly what his boss said-( Boss says: Bubba put one of them there coolant filters on that 200 and make sure its easy to get to! Bubba says: Yes Sir. Just the way I look at things. Scott
orangereborn
Posted: 24 May 2017 at 11:51am |
I would say exactly nothing. In fact worse than no filter. The lines are hooked to opposing pressure. Would think it may work some when the cab heated is on. But when it is off, the pressure is reversed and flush the filter contents back into the system.
orangereborn
Posted: 24 May 2017 at 11:57am |
Thanks for the vote of support. Is the NAPA Prestone Command SCA what others have mentioned? Or your preference? Thanks....Dale
Edited by orangereborn - 24 May 2017 at 11:58am |
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11173 |
Posted: 24 May 2017 at 12:00pm |
One thing about it , change filter and all the anti freeze is going to run out with no shut offs
Posted: 24 May 2017 at 12:10pm |
I use Caterpillar coolant now. I'm sure Cummins has similar and others as well. I started using Nalcool 2000 back in 1976 and have never had a sleeve pitting issue or O-ring failure since as long as the coolant was treated correctly. We told Customers to change coolant every 2 yrs and use distilled water + good antifreeze + Nalcool 2000.
DougG
Posted: 24 May 2017 at 7:06pm |
Wow I'm a shadetree mechanic, but dayum I can do a lot better than that bs
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8759 |
Posted: 24 May 2017 at 10:30pm |
Cat,Cummins,Shell all got their names on 5yr-500000 mile premix
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1530 |
Posted: 25 May 2017 at 3:30pm |
Coolant filters are still a good way to go even with good coolant. You would not believe the crap we are seeing in the new diesel engines in the coolant filters most notably the Mack engines. After changing the coolant filters once or twice they are running clean. Initially they are full of grey sludge - from some sort of building process or whatever???? Mack of course denies there is a problem!! LOL.
SteveM C/IL
Posted: 26 May 2017 at 7:23am |
.....nothing to see here!!........
