Buying Roosa Master bolts
McGatha185 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote McGatha185 Quote  Post ReplyReply Direct Link To This Post Topic: Buying Roosa Master bolts
    Posted: 02 Jul 2017 at 5:03pm
I need to know where I can buy a new set of banjo bolts for my Roosa-Master injection pump. Mine's got some boogered up threads on a couple of them. It's on a 1970 185 Allis and it's a Roosa-Master DBGFC-637-34FW pump. I've searched the internet and I'm just not finding what I need, but I know there has to be companies out there selling replacement parts for these. I'd prefer new ones.
Thanks for the help!!
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 7:47pm
I ordered some banjo bolts from a diesel repair shop.  Most any of them should be able to get them for you.
ALWAYS use new special sealing washers under the bolt and  the pump. Many equipment dealers should have these washers on hand.
I highly recommend you replace both washers on each line.
The bolts require a 9/16 box end or socket.  They are fine thread.  Start them by hand when replacing the bolts, to avoid cross threading.
The torque is around 35 ft. pounds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 9:40pm
and that 35lbs feels like it aint going to get there....scary!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 7:13am
When installing banjo bolts, leave the mounting stud nuts loose on the pump so it can wiggle around a little and do NOT tighten ANY banjo bolts until all six banjo bolts are threaded in by hand with some WD40 on the threads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 11:50am
I always draw them up tight, loosen, then retighten gets everything where it needs to be
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 1:04pm
Deleted.
Edited by Ed (Ont) - 04 Jul 2017 at 12:12am
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 2:22pm
Well, that's news to me. I always thought those bolts were special from Stanadyne/Roosa Master and that was thee only place they could be had.
