Antifreeze
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Topic: Antifreeze
    Posted: 12 hours 57 minutes ago at 11:36pm
This may be a dumb question but can antifreeze settle out? I have an old nat gas powered pumping unit that has been sitting in the barn for the last 4 years. Before I parked it I changed the oil and antifreeze and then ran it for a few, maybe 10, minutes. I pulled it out a couple weeks ago and the antifreeze in the rad was slushy close to solid actually. I opened the drain on the block and it was fine. Put it in the heated shop and let it thaw out and took a closer look at it today. Antifreeze from the top of the radiator tested good to -8 celsius and the first stuff out of the block was good to -40. I mixed it all back up and it tested good to -29 which is about what it would have been when I put it in. How is that possible?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 13 minutes ago at 6:20am
Never heard of that, never given it much thought. I suppose it's possible? It may not have mixed completely in the short run-time?
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 5 minutes ago at 6:28am
That initial 10-minute run time was not enough to thoroughly mix it.  You should have run it up to temperature so the thermostat opened and kept it there for at least 10-minutes to circulate and mix the entire system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 51 minutes ago at 7:42am
Especially if you dumped in a gallon of straight antifreeze and then a gallon of water and then didn't allow it to reach operating temps (open thermostat).
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 40 minutes ago at 7:53am
I always premix 50/50 in a five gallon bucket coolant to distilled water ratio with ethylene glycol. Have never seen it separate in the past. Typically I use "Prestone" for automotive use and "Fleet Guard" in low silicate formulation for industrial and truck engines.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 30 minutes ago at 10:03am
I always premix my antifreeze as well but just use tap water. Now a bit more information. I bought and mixed up a 10 litre jug of concentrated green antifreeze (actually 9.46l) a bit under 50/50 to give me about a -30c rating and topped it up with another 6 or so litres of the red stuff. All compatible. Now the stuff that came out of the block was nice and green but the stuff in the rad was the funny greenish reddish brown cloudy color. No actual rust or other gunk in any of it. I can't say I ve had an issue before but maybe the different types were not as compatible as the instructions indicated? But that wouldn't explain why the concentration varied from top to bottom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 22 minutes ago at 10:11am
As noted 50/50 mix drain and refill after full flush and then run to operating temp and Confirmed flow.  Should not ever Settle or Separate.
Are currently Four types out these days, Old Green, Orange GM, Orange Ford, Red Hi Nitrate HD Diesel.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 22 minutes ago at 11:11am
If using the green traditional stuff then use only that. Do not mix any of the new types with it no matter what colour and there is every colour under the rainbow out there. The new ones are OAT(organic acid technology) whatever that means??? So choose one - old technology or new tech. Either way drain system and start from scratch. If you go green you have to change every it every 2-3 years or keep it maintained with a filter and dca system. The new stuff lasts longer but still needs to be changed periodically. The red stuff for big diesels claims to have a lifespan of 1.6 million km. I would not let it go that long!!! Smile
Edited by Ed (Ont) - 1 hour 21 minutes ago at 11:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 38 minutes ago at 11:55am
there is a YELLOW  "Extended life 150,000 miles" that replaces the green... Much better stuff.. been around for 30 years..... This is NOT the NEW YELLOW that FORD has been using for the past 5 years...
The ORANGE that FORD used in the 2010- 2020 era on MOST vehicles is the same as DEXCOOL used by GM for many years..
your  right.. DO NOT MIX  any..
