Another 190XT no start
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Topic: Another 190XT no start
    Posted: 26 May 2024 at 6:56am
This time not necessarily a request for advice but rather what I've been dealing. Feel free to pitch in though.
This tractor is new to me and always started great till just a week ago then yesterday no start no smoke. There is no primer on this tractor so I disconnected the fuel at the injector pump and had almost no flow. Went to the inlet side of the fuel filter, again almost no flow. Back to the sediment bowls
Screens are clogged. This stuff is gooey and sticky like uncredited gasket sealer. Presumably bio diesel crud. Anyway, got it all cleaned up.
Decided to drain the tank completely as the fuel left in there is cloudy
I poured some gas in the tank to act as a solvent to cut the crud as that appears similar to molasses. I clanped a brush on a stick to scrub some. Obviously I can't get all of it due to the baffle but some is better than none. I now have 10 gallons fresh diesel, clean sediment bowls and new filter. Have good flow out the sediment bowls but not so much from line itself. I did get the tractor to start and run briefly but I think there is still a restriction in the supply line. Ran out of time yesterday and this is an outdoor project with rain today's so will have to wait some.
Thanks for looking
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2024 at 7:37am
I haven't used any screens for 40 or more years. It's always the first place that gives problems in the winter time. The fuel filter catches all the dirt. Throw the screens away to eliminate a problem at that point.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2024 at 8:00am
Take the tank to a shop to get completely cleaned out and your problem will be eliminated.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2024 at 8:10am
My xt sat for 28 years when I got her. Ended up power washing inside tank. Threw away bowl screens. Not an issue since.
Blue Skies and Tail Winds
                          Dana
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2024 at 9:38am
Clean up fuel system as best as you can and treat fresh fuel with bio kleen.  Sounds like algae
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2024 at 9:41am
I'll get the screens out. Gonna replace the gaskets as one is leaking now.
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2024 at 11:21am
I dealt with a bad fuel line, gunk in tank, bad sediment bowls all at the same time so I feel your pain.  I have often wondered if the tank cleaners can really get the gunk out with the baffle?
I drained my tank multiple times.  My needle valves in the sediment bowls got restricted multiple times until I got it all out.
I also do want to relate a story about removing the screens.  I left the cap off of my fuel tank, mowed 2 acres of weedy, fluffy seeds floating around.  A bunch of seeds got into my tank, and clogged up the check valve in the primer pump.  It was self inflicted.  The primer pump is in front of the fuel filter.  Otherwise, I think screen removal is fine.
80 7010, 80 7020. 67 190XTD Series I w/500 Loader, AC 2000 Plow, AC 4 row Planter, AC 77G Rake, Member Indiana A-C Partners, Member TAC
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2024 at 4:22pm
To each his own but I leave my screens in as they were designed to help keep dirt out. Cleaned them 8 years ago when I got the XT and haven’t had to touch them since. I never run Bio Diesel, I am not a fan of it. Thankfully there are plenty of stores that sell off road diesel for my tractors. Cleaned your fuel containers and wiping the fuel cap and neck with a clean rag before refueling will keep dirt out of your tank. Realizing this is new to you the only good way of resolving your issue is a really good cleaning of the tank.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2024 at 11:25am
I would unscrew the sediment bowls from the tank and insert about a 2" long roll pin in the middle of the bowls to stick up in the tank - this will prevent a 'sink stopper' effect if a rust flake occurs. The slot in the roll pin will allow the tank to drain .  A stand pipe will never let the tank drain and the results are not pretty. With today's fuel and algae, I would vote no on the screens. The main reason is they are so hard to get to at 70 years of age... the fuel filter is not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2024 at 2:33pm
There is nothing more unpleasant that cleaning screens in the wintertime cold while the fuel is dripping off your elbow !!! Throw them away !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2024 at 2:54pm
Screens are out. At present, I am not able to get fuel through the injector pump to the injectors. Have loosened 3 lines at the injectors. Nothing so far but now also fighting an intermittent starter solenoid and maintaining battery charge. To think, all I wanted to do was try to isolate a buzzing hydraulic line from the pump tooil cooler
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2024 at 3:14pm
I typically run a 90/10 mixture of diesel/acetone through a system that is sticky or gummed up from this crap biodiesel we have. Have a spare set of filters with you as the sludge and grime will release with the filters catching it. If really bad, filters will plug, but the fresh fuel and acetone act very well together and don't seem to hurt anything; or at least hasn't for me in many years with diesel engines of several types. You could also use naptha, but the desired results take longer to achieve. Many times transfer pumps and their check valves are the first things to stick precluding fuel flow and this mixture will get them freed back up and working. Same thing with injectors.
That's All Folks!
Post Options Post Options   Thanks (1) Thanks(1)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2025 at 1:34pm
An update
Apparently this tractor has had a combine engine swap according to someone looking it over at the consignment auction where I got this.
There are electrical gremlins under the dash of this thing. The start button is good, the safety switch is good, power to the starting system is sketchy. I can bypass all that and jump across the starter solenoid and starter works as should. All safety should be observed when using this method
It does not have a fuel primer pump so I put an electric pump in to compensate.
I also removed the fill cap and fuel level sender and stuck a swab on a stick to scrub the inside of the tank as best I could with gasoline. Replaced the cap and sender, sediment bowls minus the screens and a new fuel filter. The electric pump is downstream of the spin on fuel filter so it will draw clean fuel. Still unable to push fuel through the injection pump. This was last year yet. At Hutch last year I picked up a primer pump from one of the vendors and hard piped it to the filter base outlet. Shortened the line to the Roosa DM. Removed the end cap from the Roosa and cleaned that inlet screen. Loosened two lines on the pump outlet and four lines at the injectors.
With my accountant operating the starter I worked the hand primer and got fuel to move through all the loosened injector lines. Tightened up all the lines and got her to run finally. At first it tried to run away so shut off the fuel immediately. It restarted and settled down to a normal idle. I drove it around a while to get the engine warm. The throttle response is a little sluggish. That was two days ago. Gonna check on her again tonight to see how it goes.
Thought you’d like to know
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2025 at 2:30pm
With the crap you had in the bowls you had it in the pump too. I'm surprised the pump functions at all. BIO DIESEL IS BAAAAAD!! for farm use.. Too much setting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2025 at 8:17pm
Tried it again tonight
No fire, no smoke, no joy
I did find the fuel supply line to the injector pump was loose. May not be out of the woods yet
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2025 at 10:43pm
"I did find the fuel supply line to the injector pump was loose"
 Check to see if you still have fuel in the tank.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:57am
Very common for the Roosa DB pumps to have the plungers stick when they sit in this crappy modern fuel we have. Tractors that sit must have as low a bio content as possible, most fuel suppliers offer a premium diesel, and it is worth the higher price!
DPKII View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DPKII Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 7 minutes ago at 9:06am
I just went through this with my 190 too.  Had the pump rebuilt by Ed and installed last year and the injectors rebuilt and installed this spring.  Tractor started and ran great!  Best its run in years.
I had drained and cleaned the tank as best I could last fall before installing the rebuilt pump.  The tractor set from sometimes in November till early March. This spring with a hour or so of running after installing the injectors it started running poorly.  Checked the bowls and found sludge in the bottom of both.
The tank had a 1/8" to 1/4" of sludge across the bottom.  Super sticky, like thick tar.  Ended up pumping the tank dry (biodiesel) by jacking up one rear or the other as I didn't want to get a diesel shower pulling the bowls with fuel in the tank.
To clean I replaced both bowls with a hose barb and ran a hose from each down below the drawbar to a catch pan and blocked the hoses with some 3/8" round stock.  I made a couple "mops) using 5/8" dowels with a groove at one end and zip tied a thick sock to each.  I used acetone a couple gallons at a time to soak the sludge and used the mops through the filler and fuel sender holes to clean inside the tank.  Went through about a dozen socks.  I could actually get the mops pretty well up the sides of the tank and baffle to scrub and agitate the acetone and also jacking each side of the tractor to flush through the hose barbs and hoses so each side was clean.  Did this a few times and flushed acetone backwards through the fuel lines with a pressure tank.  Finally flushed everything with clean diesel to get rid of any remaining acetone.
Had to clean the metering valve in the pump as it was gummed up with the sticky sludge as well.
This time, talked to a local hay farmer and bought premium farm diesel from him.  He said he hasn't had any sludge problems and he has a few old tractors that sit most of the year.
Hopefully I have cured my tank problem.  I also had been using stanadyne additive and will continue to do so.  This time I also am using some bioclean additive for the first tank or two..
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 26 minutes ago at 9:47am
There should be a disclaimer with every sale of biodeisel. "Warning-do NOT let vehicle/equipment set for extended periods when using this product."  It's like recap tires. Cheaper initial cost but risk of damage outweighs savings. Left 1/2 tank in F2 one winter and rusted the crap out of fuel tank. I burn it all the time in my road truck but it doesn't set around. Some farms use it through busy season but switch to straight diesel near end to clean out systems for over winter. (hassel) I don't know if soy oil biodiesel causes trouble but there's alot of bio that isn't soy based. I don't chance it with farm equipment. Straight diesel only. Does it really cost more in the end?
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 19 minutes ago at 10:54am
I believe straight diesel is worth the cost for peace of mind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 12 minutes ago at 12:01pm
FWIW, the problem began with the fuel that was in the tractor when I bought it. I never gave it a thought then cuz it ran well for a couple months with little use. It literally ran when parked then this after a week of sitting. All of the existing fuel has been drained, cleaned, flushed and the fuel filter replaced. I believe what I am dealing with now is a sticky residue left in the pump.
I do not use bio diesel from any convenience store outlet. Rather I have fuel delivered from the local ag supplier and believe there is no bio in it.
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 35 minutes ago at 12:38pm
That sludgy, sticky residue is a result of 'Diesel Algae' or 'Diesel Bug': The byproduct of a bacteria that can live in diesel fuel, feast on the hydrocarbons, and leaves a sticky residue in its wake. If it's left unchecked, it can cause a real nightmare, plugging the whole fuel system up with that sticky residue and wreaking havoc with injection pumps.
It used to only be a problem in marine diesels, where the humid environments would promote its growth. Now, however, it's increasingly problematic in other diesels. It's not strictly a 'fault' with modern diesel fuels, but its increasing presence is a result of modern diesel: The sulphur content of older diesel fuel hampered the bacteria's growth. Now that all diesel is low-sulphur, it's a lot more common.
To kill the bacteria and prevent it coming back, you need a diesel biocide to treat the fuel. Other additives won't do squat to kill it. A decade and more ago, you'd have to go to a marina to find diesel biocide. But now that it's becoming common, lots off other places carry it. The Case and Kubota dealers near me have carried it for a few years now, and my local Napa started stocking it a few months ago. The most common diesel biocide is called 'JF Biobor'.
Google 'diesel algae' and you'll see lots of pictures/info on it. Once the sludge is established, methyl hydrate is one of the few products that will help break it down. Methyl hydrate won't kill the bacteria though; you need a good dose of biocide to kill it so it doesn't come back. Any diesel that's going to be sitting for more than a couple of months should have a dose of biocide put in it.
Edited by DanielW - 8 hours 27 minutes ago at 12:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 12 minutes ago at 2:01pm
Around here you need to specify NO BIO to the delivery truck. As said,some BTO's use it during season. Some outfits spend 2 months or more at harvest then tillage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DPKII Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 52 minutes ago at 2:21pm
I wasn't familiar with methyl hydrate.  I haven't noticed in stores around here but since it is labeled as a deicer I am not surprised as not too much of a need of it here on the Texas gulf coast.  Looks like it would have been a little cheaper than acetone.  We do have plenty of humidity which definitely promotes the algae growth.  E85 was also suggested to me but stations here don't sell that either.
I did some experimenting with the common volatile cleaners found locally such as brake clean, carb clean, lacquer thinner, etc. and found that some would cut the slime but acetone did it much better than the rest. The best aerosol I tried was the Evinrude/Johnson carbon clean.
Also, keep the acetone away from your decals.  I was trying to be very careful but had a bit left in the edge of the funnel when I took it from the filler.  A few drops of acetone dripped down the back of the tank.  I immediately wiped, but the color on the Allice Chalmers decal smeared.
Yes, I wish we still could get the old farm diesel that grandpa used to run.  Never had any fuel issues back then and the tractors sat outside all winter without being run.
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 23 minutes ago at 3:50pm
The premium diesel sold by most suppliers does smell just like good old fashioned diesel fuel. The bio diesel blends tend to smell like latex paint to me. E85 can be hard to find, but worth hunting it down as it's an effective solvent and it's relatively inexpensive.
