8000 4WA ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: 8000 4WA ???
    Posted: 10 hours 2 minutes ago at 10:45pm
Hello everyone.
In parts book it says “change effective on tractors equipped w/no -spin 4WA axle only; std 4WA axles use original parts.”
What does this mean and how do you know what you have.
Also in parts book theres sr break on some 4WA parts. Is this the tractor sr number or front axle number.
Thank you
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 50 minutes ago at 10:57pm
Some units had a Detroit Locker in the differential.  We had several before the fire we got in a tub from the West Allis tractor sale.  This was a limited slip item.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 5 minutes ago at 6:42am
8010-8070 "FWA" front axles had a metal tag on the axle with a code that told you whether it was a standard axle or a locking axle.      7580/8550's and 4W-220/4W305's "4WD" tractor front axles I assumed there was something stamped into the casting like they would have stamped a serial number.  Your post says 8000 "4WA" which I take to mean an 8010-8070 model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 47 minutes ago at 7:00am
Thanks for the reply.
Yes a 8050
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 42 minutes ago at 7:05am
8000 series FWA tractors have a metal tag on the front axle. The model number will have an N stamped at the end of the number if it has the no spin differential.
