7580 Cab
Acfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acfarm Quote  Post ReplyReply Direct Link To This Post Topic: 7580 Cab
    Posted: 07 Sep 2016 at 11:07pm
Can a 7580 cab bolt onto a model 7000 tractor? Reason for asking is have a parts 7580 out back and a 7000 in need of a cab...... Thanks!
~Warren
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 12:47am
I think the only difference is the door opening different...are the controls the same inside the cab?
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 6:48am
7580 has a larger door that opens opposite direction, dont think it will clear the tire and it has no fender wells.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acfarm Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 9:47pm
I was planning on swapping the controls out since the levers are different.
Fender wells are not a big deal.... I will check the door clearance.
Thanks!
~Warren
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 2:14am
It would look pretty cobbled. the 4wd cabs were based off the 2wd cabs, but they are quite different.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
