7060 cab floor |
whatscooking
Topic: 7060 cab floorPosted: 27 Sep 2026 at 7:18am |
Have had the cab floor out going after leaks. When I pulled the mat there was a piece of angle laying by the console unhooked under the mat. Bolt holes line up, only one in console has threads and one on floor. Saw a Pic of a ragged out 7060 that had that angle on top of the mat with one bolt into console and one into the floor, looks only as a matt holder,is that correct?
Also obviously that console side cover has got to come off to get to the cable ends. How scary of a project is it to open that up? Edited by whatscooking - 27 Sep 2026 at 7:19am |
68 D21 81 7060
Posted: 27 Sep 2026 at 7:24am |
Angle iron at the front corner ?? bolts to the floor to stabilize the console assembly. That was added when they went to the "T"-shifter for the Power Director and even tho it may be a Power Shift, still had that brace. It isn't for the floor mat.
whatscooking
Posted: 27 Sep 2026 at 7:25am |
Top or under the mat?
68 D21 81 7060
Posted: 27 Sep 2026 at 7:52am |
UNDER ...directly to the cab floor for a brace/support.
whatscooking
Posted: 28 Sep 2026 at 2:06pm |
Got it except the front bolt into the console. No threaded nut attached inside.
Now since I do not have a shop manual I have to as some silly questions. Is that panel on the side of the console designed to be opened up without all the levers falling apart? It looks as it has to be able to change the various cables. Edited by whatscooking - 28 Sep 2026 at 2:07pm |
68 D21 81 7060
Posted: 28 Sep 2026 at 2:26pm |
Top panels come off and side comes off. Do not tighten ANY hardware until you have ALL the bolts started when assembling.
whatscooking
Posted: 30 Sep 2026 at 6:03pm |
Edited by whatscooking - 30 Sep 2026 at 6:04pm |
68 D21 81 7060
Michael B
Joined: 2 hours 43 minutes ago Location: WA Points: 3 |
Posted: 1 hour 46 minutes ago at 1:52am |
Ive just had the side and top covers off to get at the cable end. The retaining lug has fallen off then lost . Take a few pics with yr phone as you pull it apart. For a big guy its really awkward in the space between the seat and under the steering wheel. Take the fuel hose off and swing the battery box forward to geta good look at it from underneath. I also took the floor plate out . My 7020 has the same angle bracket to support the side plate . . . Not a job i would want to do every day . . . none the less a great machine with a 7 foot slasher on the linkage . . .
