7000 throttle slow to respond
ACFarmer86 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer86 Quote  Post ReplyReply Direct Link To This Post Topic: 7000 throttle slow to respond
    Posted: 08 Jun 2017 at 9:21pm
So I just purchased a 7000 and in driving it home I noticed that when you throw up the engine revs up slower than I feel it should. It's not "snappy" like my 190 and 185. And when you pull down fast it kills engine just like fuel shut off. Was told the fuel filter was just changed before I picked it up. Could it be pump, I'm just not sure
Grandpa's 1953 WD, D17 series I, 190 XT III
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 9:32pm
check the turbocharger. Otherwise it may be the injection pump.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 9:36pm
Sounds like the governor in the pump is sticking? Was the tractor airing a long time before you got it? Might be worth bleeding the system again to make sure, and fuel filters aren't too expensive if you want to try that before a pump rebuild. Ed on here will probably chime in, and I'd just do what he says. Hasn't let me down yet!
Hurst
1979 Allis Chalmers 7000
5800 Hours
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 9:58pm
sounds like the pump is gummed up you can try some additives or pull pump and have gone threw
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer86 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 10:55pm
Should have mentioned that it has only been run a few times a year the last three or four years since the gentleman I bought it from retired
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 7:42am
metering valve in the pump is sticking if not billowing black smoke when throttled up. If it is billowing black smoke, but lazy to respond, then look at the turbo as stated above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer86 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 10:20am
It smokes black and gets up to rpm just slowly
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 10:21am
Anything under about 17 to 1800 RPM you are going to have that....sounds pretty normal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 11:01am
check around intake manifold, looking for missing plug, or blown gasket. Have seen this more than once. Also could be an exhaust leak before the turbo if the manifold is cracked, blown gasket, or rotted out turbine housing.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 2:24pm
A 7000 for some reason is worse about gumming up metering valve and pin that governor spring sets on than any of the 7000 series. MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer86 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 3:21pm
Thanks guys I will look in to it tonight after work
45 turboa- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2017 at 4:56pm
I would ck the air cleaner too.  Pull the hose off the turbo and see how it acts then.
turbocharged
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2017 at 12:18am
Better of taking filter out
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer86 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2017 at 8:54am
I had a few mins last night to monkey with it. It has ok response in the upper end of Rpms. The hand throttle needs to be half way up before it comes of idle, and the foot is better but still takes quite a bit before it starts to react. Could cable be bad or that far out of adjustment? And if I rev it up and take my foot off the throttle it will die. According to the previous owner it always kinda been like this.....
