7000 gettin some air
Bob C IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Topic: 7000 gettin some air
    Posted: 01 Aug 2012 at 8:04pm
Ran great till she bent all her rods and destroyed herself
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 8:38pm
I think Doug was looking for a "7000 fixer uper". It still amazes me any of those tractors stay together goin down the track.
Leon B MO
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 10:50pm
Bob did you find you a block?  Do you pull in that IPA circuit ?  If you want that 301 to run with them talk to Bernie Platz he can make a 301 scream
                                            IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 4:29am
They will come apart! IG, just curious of what kinda puller ur putting together? Thought i read on another post u had one cooking, its alot of fun!
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 6:22am
Thats one of the things Doc said was to have hard rods when you turn them up that much. I like seeing 7000 series more on the circuit.
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 8:25am
Yes hard rods are a must when you have them turning like that . I am only running 3500 rpms and I have hard rods and a few other little extra hardened bored and stretched shrunk and welded together things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 1:57pm
No on New motor. New I would have trouble just wish it would last longer, 2 years ain't bad. And yes I do pull with the IPA group.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 2:01pm
Do you still have the Rossa on it ? What gear do u run ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 3:34pm
Dm4 631 pump 4 x 18 injectors. Run 4 under gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 3:53pm
I'm disappointed. I thought I was gonna see the video of it venting itselfUnhappy I guess it happens to the best of emSmile
I guess by getting some air, you meant the wheelie?
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 7:56pm
She is getting some air, no doubt, but she is getting a pretty good dose of fuel to go with it! Looks great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2012 at 6:22pm
Just bought 5.9 to install. Machine work galore......
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2012 at 11:14pm
So will you put Agco sheet metal on it or will the association you pull with be ok with the 5.9 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 10:35am
Bob I have some Agco sheetmetal if they make you put that on. I have the Acgo Allis hood that had a cummins motor under it.
                                                   IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 8:33pm
Nope can use my 7000 sheet metal.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 11:48pm
Thats great !!!! They gripe over here in the brushpullers if you dont have the right sheetmetal with the right motor. Because its orange...lol So I put an Agco hood on my 7040 that should cover all of the engine choices. But it will have the 426 under the hood
                                                  IG
This page was generated in 0.085 seconds.
