7000 Clutch issues
gilduane View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gilduane Quote  Post ReplyReply Direct Link To This Post Topic: 7000 Clutch issues
    Posted: 09 Aug 2026 at 9:08pm
What am I doing that's not right" When the clutch is pressed the clutch does not disengage, what's wrong " on a Allis 7000 s/n8045
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2026 at 9:50pm
Maroon chassis with gear shift on the floor ??  Probably the throw out bearing has failed. There is a cover under the bell housing you can remove to verify.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2026 at 10:19pm
sn 8045 , I'm guessing its a black belly tractor?  If so, its a wet clutch tractor, it could be as simple as a transmission brake adjustment or it could have warped plates in the low range of the 3 speed PS, which serves as your inching clutch.
