4th Gear in a 180
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: 4th Gear in a 180
    Posted: 08 May 2025 at 7:21am
Just wondering if anyone could tell me what the tooth count should be on 4th gear (input shaft) on a 180/185?  I have two transmissions, and one gear has 36 teeth and the other gear has 42 teeth.  Thanks.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2025 at 10:33am
70256571   19 tooth with 15 coupling teeth.   The only one I know of on a 180
70245780 20 tooth 20 coupling - first 190
70245722  19 tooth
70246407 19 with 12 coupling
look on the input gear to see if there is a snap ring groove cut in - if so it is a D series.
Edited by tbran - 08 May 2025 at 10:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2025 at 11:31am
If you have 36 and 42 teeth on the input shaft to the transmission (direct drive/4th gear) it is custom made. They are usually two parts: a gear (36 or 42) and an input shaft with splines and a snap ring groove to hold on the gear on those splines. A gear that large will not fit thru the input shaft bearing hole in the trans case. A gear that large is assembled from the rear being slid onto the input shaft while the shaft is being installed into the trans case from the front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2025 at 8:06pm
I’m trying to attach a photo of the gear, but the file size is too big
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2025 at 4:21pm
This is medium size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2025 at 4:25pm
Kevin I will post a couple pics here that may help you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2025 at 4:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2025 at 4:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2025 at 4:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2025 at 4:33pm
Look at top pic. See where it says actual size at bottom of pic. Tap that and it will give you the choices you see in middle pic. Choose medium and use that. I find that I usually try twice to get it to load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2025 at 4:38pm
Do you have some young kids hanging around. They will walk you thru it. Keep in mind I am doing this on my iPad. Apple format. PC format gonna be bit different. But again some young kid can help.  Or Jay!!Smile
