426 bearing questions
977.3Ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 977.3Ford Quote  Post ReplyReply Direct Link To This Post Topic: 426 bearing questions
    Posted: 26 Aug 2025 at 7:43pm
Had a post the other day about my 8050 throwing a rod, ended up finding a deal locally on an engine out of a late N6 with 4500 hours. I pulled a main and rod cap off last night, they show some wear, nothing too crazy though. Need to get this engine back in ASAP, but i'd like to roll new bearings in while the pan is off. Rod bearings and bolts seem pretty straightforward, the main bearings have me a little confused. From reading around it looks like to use new bearings i would have to drop the crank and plug the holes in the block, but i've seen a couple posts talking about just replacing the bottom shells and leaving the tops in. Given how these bearing looks, is that the way to go?
Jimmy
1982 8050 Powershift
1982 6080
1992 R52 Gleaner
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 10:15pm
If it was mine, bottom shells is all it would get.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:54am
  I have gone that route a couple times.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:12am
That main looks really good   especially if it's got all those hours. I agree with just replacing lowers. What's the date on the back?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:50am
Yup, also I would definitely go back with ARP rod bolts thru Agco.  It probably doesn't apply here, but there was also a bulletin about reversing the slotted rod brg / rod position - do you remember anything about that Doc ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:23am
Yes. On older engines with 4-rings pistons, you are to turn the conn rod 180 degrees when reassembling. So, any of the 4-ring/small piston pin engines pre-8000 series this applies to.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:42am
is thier anything about rod and main bearing changes in the knowlage section might be good to have those service bullitins thier be cause that gets confusing if you are turning rods backwards and plugging oil holes   an older manual my not show the correct changes
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 10:00am
OK so his N6 replacement engine will have the 3 ring piston -big pin-  and this will not apply. This will be the rifle drilled rod just like the 8000.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 21 hours 60 minutes ago at 12:12pm
What was the purpose of flipping the connecting rods?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 23 minutes ago at 7:49am
Testing showed better wear with the flip. If you look at brg you see more material to one side VS other. The direction of rotation applies load to more brg material. I could get the direct quote from service manual but....
I strongly suggest using the 2 feeler guages between rod and crank to help keep cap square. Kinda a pain but doable.
Edited by SteveM C/IL - 2 hours 20 minutes ago at 7:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 48 minutes ago at 8:24am
I was always taught to snug the rod bolts. Then take a hammer and tap the end of the rod cap sideways both ways. This will square the cap and then tighten/torque the bolts. I had a kid one time decades ago who didn't do that on a 190XT engine OH. The engine idled about 30 seconds and locked up from the corner of the rod cap gouging into the crank throw side. Careful dressing in-chassis with a die grinder (by me) saved the day. He was soooo close to being fired that day because he had been told the proper procedure and didn't do it. He just didn't think it was that important.
