190xt injection line seals
A&Sfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A&Sfarms Quote  Post ReplyReply Direct Link To This Post Topic: 190xt injection line seals
    Posted: 4 hours 17 minutes ago at 9:45am
Did an overhaul on the engine including injection pump and injectors for my 190xt 2 winters ago. The kit came with white plastic washers for the banjo bolts on the injection pump and some have always leaked, but the leak is getting worse. Bolts were torqued to spec upon install and have been tightened up as far as I feel comfortable since trying to get them to seal. I went to the dealer and they had aluminum washers with a smaller plastic washer inside as replacements at a cool $20 per washer. Needing 12 of them bad boys was going to cost a pretty ridiculous amount. The parts guy pointed me to a Deere dealer with what looks like a black oxide washer for $0.13 a piece. That was cheap enough for me to go ahead and buy and see. It has been way too cold for me to get them installed yet. Do you guys have the answer on this? Are the 2 piece, $20 washers the answer for a good seal? I was expecting copper, but no one offered that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 26 minutes ago at 10:36am
Black. Get them tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 14 minutes ago at 10:48am
black Deere one are what you want. Everything clean of course. Book say 35 ft lb IIRC. It's a scary pull and some impossible to get a torque wrench on. I do by hand and get em tight as Doc says.
Post Options Post Options   Thanks (0) Thanks(0)   Quote A&Sfarms Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 32 minutes ago at 11:30am
Thanks guys. Good to hear I ended up with the right ones then. And the cheap ones for a change! Definitely didn't tell the Deere guy what I was working on.... just in case.
PaulSamwel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 3 minutes ago at 11:59am
Working on a 185 with pump issues.Would those Deere seals your talking about be part number T20055?
This page was generated in 0.184 seconds.
