180 questions |
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5237 |
Topic: 180 questionsPosted: 16 Oct 2026 at 9:22pm |
There's a 180 for sale about a hour or so from here and I'm looking for a backup for my Kubota M6800. According to tractor data, the 180 is quite a bit heavier than my Kubota which would be a good thing. Only issues I can see are the exhaust height and the low gear speed. According to tractor data the exhaust height is 90". Is this right? That would put the exhaust at 7 1/2 feet? I know I can cut the pipe. Just seems mighty tall for a 70 hp tractor. Also is the 2.1 mph in 1st gear correct? My Kubota with 28" rears runs about 1.6(?) I think and can run out of power with a windrower in heavy litter. Think of a windrower as a 6 1/2 ft tiller 6 inches deep in heavy soil. Even if it's not the best option or just flat won't work I'll still call about the tractor. Any quirks other than the normal gear jumping?
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5322 |
Posted: 20 hours 36 minutes ago at 5:34am |
I have spent a lot of hours on a 180 and 185. I don't think you will find low gear too fast for any job.
Dad's 185 had 30" tires and the 180 had 28". The 185 was a bit faster, but still not too fast.
whatscooking
Posted: 20 hours 24 minutes ago at 5:46am |
What ya intend to use it for, what other kind of implements can you hook onto? When we finally got a 180 on the farm it got used for everything from pulling a 4 bottom plow through tough soil, pulling a 6 row no till Planter to square bailing. I dont think a windrower will bother it, but I'd have never pulled one ither.
Edited by whatscooking - 20 hours 9 minutes ago at 6:01am |
68 D21 81 7060
thendrix
Posted: 18 hours 52 minutes ago at 7:18am |
It'll mainly be used for litter work in my chicken houses. That's the reason for the height concern. About the only other things I do with a tractor around here are maybe a rotary mower and if we decide to cut a little hay for our goats it'll get mower and baler duty. I haven't seen the tractor but the guy is asking $4k. $4k for a 70hp tractor, even one this old, I'm not expecting a whole lot.
thendrix
Posted: 18 hours 25 minutes ago at 7:45am |
https://youtu.be/kBlj5yxzO0E?si=q8B1MwQQ57qPp6y2 He's a video we made about windrowing that explains it a little |
Modern tractors are lighter per HP than something from the 1960's. That Kubota weighs 5,000 lbs dry/no cab and a 180 is 6700 lbs dry/no cab. Muffler stack height a problem?? Well, that can easily be dealt with.
Edited by DrAllis - 18 hours 3 minutes ago at 8:07am |
thendrix
Posted: 17 hours 4 minutes ago at 9:06am |
Well.... He sold it already. Guess I'll need to be quicker on the draw next time. Thanks anyway
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3807 |
Posted: 9 hours 30 minutes ago at 4:40pm |
thendrix, great informative video. Thanks for sharing. Looks like your Kubota & Predator make an efficient combo? It’s MFWD, shorter wheelbase, front loader, is probably very handy & somewhat better suited to the Predator 6.5’ width.
You mentioned that a 9’ wide Predator might benefit tractor wheel widths & bldg’s width? Maybe keep an eye out for another AC 180 or 185, especially if it could be matched to the larger 9’ wide Predator? Think it’s larger size & its AC 301 649 diesel should power it fine? Wondering if the 180/185s left wheels, if spaced all the way outside, might help straddle the Predator’s lefthand windrow making its 9’ swath more complete? Anyway, maybe consider a trip to your local farm & fleet to pickup a pesticide respirator that has replaceable cartridges? It could provide you a better facial seal & filtration to minimize that nasty litter dust inhalation? Decades later, you’re lungs should be healthier & happier when you’re chasing after your grandkids… ;) |
Trinity45
Joined: 17 Mar 2014 Location: Kentucky Points: 2386 |
Posted: 6 hours 35 minutes ago at 7:35pm |
The motor is the 180 is a hoss for it's size and you can turn them up, I don't recommend it, but I know a guy down the road from me, with a turned up 180 with snap on duals pulling a 20ft disc and he says he has no problems, I figured he would tear out his rear end but he is still going.
