10’ wheel disc
iron79head View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iron79head Quote  Post ReplyReply Direct Link To This Post Topic: 10’ wheel disc
    Posted: 04 Jan 2025 at 2:26pm
Laid eyes on a 10’ SC wheel disc today’
Question ‘
How hard would my 45’ snort pulling this disc’
45’ has ‘
3 slab weights
NF
Inner/outer front wheel weights
Rear wheel weights
Sandy soil
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 3:36pm
In those conditions, I'd say its a moderate load...
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 6:33pm
Depends on blades too
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 6:52pm
If it is a snap-coupler disk and your tractor's traction booster works, it should be perfect pair.
Leon B MO
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2025 at 7:44pm
I have a wide front WD 45 with loaded tires (16's) and our soil is all sand.I actually think the old girl pulls my 10 foot disc better than my D17.Both traction booster systems work.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 3:22am
Should just play with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote iron79head Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 4:29am
Thanks everyonefor the response!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 6:17am
My 180 and I get along with a 12' Massey 500 wheel disc, tank of a implement on 10" Disc Plates, cuts like no tomorrow and makes the old 180 pull down hard.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 7:27am
A WD45 and 10' disk are about a perfect match. I have boht and they work well together
Post Options Post Options   Thanks (1) Thanks(1)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 7:41am
Here's video of my NFE 45 pulling a 14" IH disc in the garden. 2nd gear in the garden, dirt is really mellow. If I take it out in cornstalks, 3rd gear works great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 9:24am
10ft behind a 45 should be a breeze.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 11:26am
I've got a 9' #109 SC mounted disc that I pull with my WD-45.  It doesn't even know anything is behind it.  You should have no problems with a 10' wheel disc.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 11:47pm
WD45 should handle 10' tandem disc. Tractor will need good tires.
 Farmall M & AC D17 pulled a JD RWA 12.5' W18" blades no problem in plowed grd. Duals would been nice to keep tire tracks down.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2025 at 10:21am
I pull a 13’ Allis disk with one tire filled, the other one leaked most all out.
Pulled it in plowed ground with the traction booster disengaged without a problem.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2025 at 11:59am
The how much disc can I pull with XYZ tractor, always make me shack my head. There are so many variations of disc's. Maybe there is someone on here that could list 75% of the models AC made. Then move out the other major brands, then all the short line companies.
I have a very similar disc to the one pictured below ( 8 blade 12 inch spacing)  (hopefully my copy and paste is viewable) that I am not sure if if any AC 2 wheel drive until the 7000 series would really handle. It took 70 hp crawler to really handle it ( HD 9 AC ).  I also have a very lite finish disc 16 foot a 40 hp 2 wheel drive handle fine.
Just saying without weight per foot and blade size not much is more than a guess. As there are discs and then there DISCS.
 Towner D32D 8 Offset Disk BigIron Auctions
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 1:18pm
My brain woke up, AC built bigger than 190 before they had the 7000 series. I guess there was a 200 that one neighbor had but a Miller 12 wheel disc was all it wanted. So I was wrong again.
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 5:34pm
     Just wondering if anyone on here ever had dual wheels on their WD-45. We had an 8 ft. disk that seemed like enough load for the 45 and always could see the rear tractor wheel tracks behind the disk till Dad got a set of duals on it. Much easier load after that and no wheel tracks. I think I was about 8-9 years old and went with Dad to Tractor Supply to get the rims and clamps.
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 6:28pm
I have duals on my D17 and pull a 12’ John Deere disk. Makes for lighter ground pressure hence the disk cuts in better and doesn’t leave wheel tracks, also makes for a lot smoother of a ride on rough ground.
Edited by Travis2766 - 10 Jan 2025 at 6:38pm
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, 1947 Rotobaler, #78 Rake, K2 Gleaner
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 6:34pm
My grandfather did.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 7:51pm
we had duels on the wd 45 and the d17d when we did tillage work but we farmed hills that the small bales would roll to the bottom of the feild when they came out of the baler . i really tought that it was cool to have the duels on when i was a kid
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2025 at 11:02pm
I had duels on my wd45d…
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 5:51am
I have a set of dual on my WD45. My uncle used them back in the70's and 80's to break open his muck fields. Same tractor, different duals.
Edited by Allis dave - 11 Jan 2025 at 5:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2025 at 8:18am
I have a pair of clamp-on duals I built for the 45's but have never mounted them to a tractor. They would fit either of the 17's now too. Maybe someday????
