wiring
 Post Reply Post Reply Page  <1 34567 13>
JTOOL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote JTOOL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 7:39pm
@Hunter321; Was the piece under the battery itself or under the battery box?
hunter321 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2021 at 10:37am
it was under the battery box in the clutch housing
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote JTOOL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2021 at 7:22pm
@hunter321; Wow! This has been a while. You must be a busy beaver LOL. I'm not an expert but I think that is the retaining ring off of the back of the hand clutch. I don't know if this means the hand clutch needs rebuilt/replaced or if you can run it OK with everything assembled. Did you ever get this old girl going?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2021 at 8:36am
no I never got it going
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2021 at 11:21am
the tractor will spin over with no spark plugs but it wont with them in is this the satrter
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2021 at 1:00pm
6 volt system has to be PERFECT to get it to go.... Could be starter , battery, cables, ground strap....... 12 volts is more forgiving and will spin it over better, thats why many convert over to 12v.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2021 at 2:06pm
could i just try a 12 vol tbattery?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2021 at 4:03pm
that would be worth a try to show that the starter is OK, and you have a weak battery or poor cables.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2021 at 4:16pm
I would not just throw in a 12 volt battery.
It would be bad for your coil, and charging system and lights.
We need a bunch of photos, you should post some if you can.
We could see how stock it is and what not.
I would be willing to speak to you on the phone or Private Messenger (a feature of the forum). I sent you a PM.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2021 at 9:43am
Try an 8 volt battery. It will work fine in place of a 6 volt, and nothing else will not have to be changed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2021 at 11:03am
ill try a 12 volt with every thing unhooked to see if the starter will turn over the engine with the spar kplugs and tell you what happens
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2021 at 12:32pm
Lift the hot wire off the coil and the generator... Crank with 12 v....If that works, you can set the 6 volt battery below the tractor and run a jumper wire from it, to the coil, and ground the other side of the battery to the frame... then crank with 12 volts, and use the 6v to check for spark / ignition.
Edited by steve(ill) - 21 Oct 2021 at 12:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2022 at 1:43pm
i borrowed a 12 volt coil from a different  tractor and tried your guys idea and it almost started but i realized i didnt have gas going to the spark plugs
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2022 at 9:16am
i got the tractor started and running for 10 min
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2022 at 9:22am
SUCCESS !!!   Clap   Clap
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2022 at 9:29am
You get a YEA for getting another step closer...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2022 at 9:30am
GREAT...how about coming here and pulling the starter outta my forklift ? The one with the flat tire, sitting outside ????
yeah, the silence is deafening........
I'm glad someone is winning though
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 7:06pm
the tractor now runs and drives
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 7:36pm
Congratulations Hunter....... How about a paragraph on what you did in the end to get it going ??
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 7:41pm
Good job Hunter. Keep at it. You’ve learned a lot already.
1939Dodge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2022 at 12:29pm
persistence pays off!
John m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2022 at 1:41pm
Good job Hunter. And a good job to you guys for helping him all through this. Getting it running does wonders for a young guys self esteem. Geez, you guys are teachers. Thumbs up
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2022 at 8:49am
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2022 at 10:10am
Nice !!! Some day, you will look back at your journal and appreciate all the effort it took to keep track of everything and the time you spent with your Dad working on this.
Good luck. I wish you lived close by so I could help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2022 at 12:22pm
Now THATS the way to TELL A STORY !!  Great Job Hunter !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2022 at 9:11am
how can i upload vidios
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2022 at 9:26am
assume you are using a computer, not phone,..
---click on "post reply" button on the lower left side of screen below the last post
---click on the "green tree" button in the new box that opens up
--click on the " choose file " button on the left lower side of the next box that opens
--find the photo you want on your computer you want to upload and select it
--------- photo can in on desktop, or in a seperate file
---click on the "upload" button below the "choose button
---look at the size of the photo... make it about 800 x 600 pixels
---click on the "OK" button on the lower right side to install that photo.
---click on the post button to post your photo
Edited by steve(ill) - 10 Mar 2022 at 9:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 9:18am
the tractor doesnt want to turn over with 6 volt and i dont want to covert it to 12
what do i do,
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 9:22am
replace the battery cables with new ones, big, fat , like welding cables NOT skimpy '12V car' cables
charge/check 6v battery ( be sure acid level is good !)
I 'cheated', went pseudo12 volt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 9:39am
there really is not much to CONVERT... With a 12 volt battery, the system is happy. You should replace a 12 volt coil... point / plug/ etc are all OK..... Dont worry about the generator... it may go ahead and charge the 12 volt battery... or lift the wire and forget it. Use it to adjust belt tension only... Put the battery on a little bench charger every 10 times you start it....... Dont need lights..
Old 6 volt systems can have weak starters, weak batteries, bad battery cables, not well grounded... EVERYTHING has to be PERFECT for a 6 v system.... as you have proven.
