wiring diagram generator
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: wiring diagram generator
    Posted: 02 Apr 2011 at 3:17pm
Does anyone have a wiring diagram for a 12 volt generator.  I installed a 12volt gen off of an A2 gleaner on my WD and used a new voltage regulator from Steve(NJ).  I have no existing wiring to look at so I need to know how to wire this thing.  It will be negative ground as well.  Thanks
Adam
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 5:45pm
This is the best I could do out of my service manual.
Danny
Danny Raddatz
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 10:01pm
6 volt or 12 volt generators are wired the same, and usually are positive ground. Alternators are negative ground. Bob
Mochaman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mochaman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 10:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 11:16pm
Don't start the tractor up till you flash the generator. Generators can charge either pos or neg ground and need to be polarized for your set-up before operating the engine or you might let the smoke out of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 3:29pm
Charlie,
I installed a new volt reg on a D17 last year and had to flash it for neg ground.  Works great now, but this tractor doesn't have any wires left (did have an alternator on it) so I had nothing to go off of.  If you have the WD45 style key switch where does the "L" wire go to?
Thanks
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 3:51pm
The "L" or load terminal on the regulator can be used to power the electrical accesories (lights, ign coil, etc) or it can be left unused and draw the current needed from the same post on the ammeter that the "BATT" wire is connected to. Not all tractors used a load terminal.
Edited by Brian Jasper co. Ia - 03 Apr 2011 at 3:52pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 4:53pm
Brian, for proper ammeter indication loads should be on the post of the ammeter opposite the one that goes to the battery. So that loads draw through the ammeter.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 4:58pm
if your regulator has no "L" terminlal----------
