wide ft for wd45
Curt-Indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Curt-Indiana Quote  Post ReplyReply Direct Link To This Post Topic: wide ft for wd45
    Posted: 01 May 2012 at 8:21pm
I have a chance to buy a wd 45 with a narrow ft. In our hills I would like to change it to a wide ft end. Does any one know if a d 15 ft will fit the wd 45 as I have a friend that is parting out a d 15.  If it will not fit does anyone know of one for sell. This will be my first allis tractor, I do have several combines and rebuild them as a hobbie. Have done 5 this winter for myself and other farmers.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 8:46pm
The front ends are not interchangeable between the two. 3 bolt, and 4 bolt wide fronts aren't too hard to find for a WD/WD45 but vary greatly in price....I've sold them for around 350.00 and some can be found cheaper but may need work. Some guys seem to think they're worth upwards of 800.00 and if you pay that much for one, two fools there met lol. A WD series tractor is a great machine that will give you good service.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2012 at 9:00am
Around here in central mo the wide front still commands a high price, there was a big salvage yard that is gone now but was in business since the 50s they had a list for wide fronts and you had to sign up and the price was 750 and there were about 12 names on the list at any given time,  they can still be had around here for around 600 but where you are in the world determines price.  1 out of every 250 tractors (guess) were wide front around here years ago as this was cultivation country, if MO isnt too far away give me a holler as I know where there are several parts tractors with wide fronts, Dustin
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2012 at 9:54am
I have a nice 4 bolt wide front for a WD45. $550 located in kansas city, mo. Depending on the year of your tractor, the 3 bolt might be the correct version, but they were prone to breaking and thus a good 3 bolt will sometimes bring a bit more as they are getting harder to find.  If it is just for work, the 4 bolt is the way to go as i have never seen one of them break.  If you are restoring, then you might want to consider the correct version for you serial # tractor.  Michael
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2012 at 10:07am
Changing to a wide front end may give you a feeling of more stability, but it is a misconception by all too many. The front axle pivots and doesn't help at all with stability until the stop is met. At this point, you are well past a safe position with the tractor. Use the widest setting for your rear wheels to help the most and stay off the sidehill if you think it might tip.
Rollover Protection
The best rollover protection advice I can give is to buy a tractor with a low center of gravity, and then operate it safely (avoid driving up or across steep slopes, slow down when turning, never turn sharply with a raised front end loader, and never hitch anything to the tractor other than at the drawbar).
In terms of the tractor's basic geometry and configuration, the biggest factors in determining its resistance to rolling over are the center of gravity and the rear wheel spacing.  The lower the center of gravity, and the wider the rear wheel spacing, the less likely it is to roll over.
The configuration of the front end matters, but not nearly as much as the center of gravity and the rear wheel spacing.  A "wide front end" is not rigid like the tractor's rear axle--it's designed to rotate about the long axis of the tractor, up to a point, so that the tractor can drive over uneven terrain and still keep both front wheels on the ground.  Until a tractor tips far enough that the wide front end rotates all the way to its stopping point, the wide front end doesn't provide any more resistance to overturning than does a narrow tricycle configuration.  My point isn't that narrow front ends are safe--rather, it's that wide front ends don't make a high-center-of-gravity tractor safe either.  If you're buying a tractor to use on hilly terrain, choose a utility tractor for its lower center of gravity.
If rollover is a real concern for you, consider buying a tractor with a professionally-installed rollover protection system (ROPS).  That pretty much rules out any tractor built before the early 60s or so, when ROPS first became available and when tractors began to be designed for them.
This page was generated in 0.081 seconds.
