Who repairs worn pedals on WD
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Topic: Who repairs worn pedals on WD
    Posted: Yesterday at 2:17am
I remember there was a member on here that could repair badly worn clutch and brake pedals on WD series tractors. I have a couple that are in need of repair and haven’t seen anything mentioned on here in a long time wondering if he still does them and what his contact info is. tia
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 16 minutes ago at 6:05am
A good machine shop could easily take your pedals and machine/install bushings in them to fit the new shaft.  Probably even drill and tap for a zerk.
AaronSEIA
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 17 minutes ago at 9:04am
AaronSEIA
x2
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 45 minutes ago at 3:36pm
70233270 bushings from a D-17 clutch pedal work I think. Takes two per pedal and grind off any excess.
kevin LA-CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 57 minutes ago at 6:24pm
I used McMaster part 6391K649. Two per pedal and cut off for length.
This page was generated in 0.073 seconds.
