Which way is better?
Les Royer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Topic: Which way is better?
    Posted: 07 Jan 2015 at 12:23pm
One WD has a coolant manifold on top of a short head that connects both coolant ports to the upper radiator hose through the thermostat. The other coolant manifold sits on a tall head and just comes off the port closest to the front of the engine and has the back port blocked off with a plate. What gives? Did Allis decide one was was better so they modified it? Or is it because one head is taller than the other? I'd post a pic, but I can't seem to get it uploaded.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2015 at 12:26pm
I think they decided one port served the purpose and they could save money by just blocking the back one off. Wat less material to just use the front one. JMO
 It may have something to do with the taller head too?????????? Maybe more room to circulate better so they just used one port.
Edited by CTuckerNWIL - 07 Jan 2015 at 12:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2015 at 1:13pm
I'm with Charlie.I think they figured out one would do.WD45's and everything later was that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2015 at 1:22pm
OK, the double ported manifold was on a 48 year, the 51 has the single.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2015 at 1:44pm
change was effective at S/N 289000 in 1951.
Gary
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2015 at 1:51pm
And, who knows what all has been changed around through the years!   Rick
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2015 at 4:26pm
Two less head studs you can't "torque" 'cause you can't get to em underneath that gul darn thing! Interesting fact Gary, mine was close to the last one then, 1951 engine 285394 and still has the larger manifold.
Edited by Bill_MN - 07 Jan 2015 at 4:29pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2015 at 9:03am
I'd expect that there's some simple answers, and probably some deeper answers. Simple is going to be a combination of improvement in performance, and reduction in cost.
Deeper answer is that they probably had all of the interests noted above, and that the combination of higher compression, better fuels, taller head, and a myriad of other changes, elimination of 'tractor fuel' option, availability of quality mechanical thermostats, better understanding of internal combustion thermodynamics, coolant and radiator flow... all added to it...
