Where is Serial #
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Where is Serial #
    Posted: 23 Jan 2012 at 11:21am
I need to order parts for my WD45 and my Model C hydraulic pumps.  I know that the serial # on the C is on the top, but where can I find the number for the 45?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 11:39am
Left brake housing on the back.  There is a flat spot, should start with WDxxx  Pretty sure they never changed the pump on the WD45 so the year doesn't matter.
AaronSEIA
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 11:41am
   This link shows where it is: http://people.clemson.edu/~wsmth/SNLocat/ACSN4.htm
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 12:25pm
Not the serial # on the tractor, I know what that is.  I need the serial # on the PTO. For kits, it says something like 'previous to serial number'... I don't think they were referring to the tractor serial #.  I don't know, maybe you guys are right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 12:30pm
   On the PTO ? Why would the PTO have any bearing on the Hydraulic Pump ? I think their talking about the tractor serial number.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 12:35pm
Ted, they are refering to the tractor serial number. Another place that a serial number is sometimes stamped is on the top flange of the hydraulic pump. That serial number doesn't always match the serial number on the tractor, I don't think any of mine do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 1:04pm
Everything I can think of on the old tractors having a serial number break always refers to the tractor chassis.  The exceptions might be out sourced parts like a diesel fuel injection pump.  I took a look at the parts manual and see no references to a serial number break in the hyd pump.  Parts were the same from the first WD to the last WD45.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 4:36pm
Sounds like what happens when you go to NAPA anymore. If you don't have the exact part # and the model it applies to, you can't buy a part. Use to walk in and tell em what I was looking for and the fellow would find it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 8:17pm
CT, you need to come to my NAPA, my Napa guy is also a tractor guy. I can call him on the phone and tell him that I need a do-hickey for a what-cha-ma-call-it and if he doesn't have it he knows where to get it. I've converted many disbelievers by sending them to Napa Tom. But I do agree, those type guys are hard to find any more.
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 8:18pm
Then You better not go into most O'Riellys, There is very few parts people that can find anything that there computer won't look up by application anymore.
1969 190XT series 3
