Wheel hub conversion
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Topic: Wheel hub conversion
    Posted: 25 Jan 2020 at 8:13pm
I always have to make things difficult .Has anyone tried to find conversion bearings so a D15 or WD - D17 front wheel hub would fit on a B spindle ? I could cut out rim centers and weld to outer rims but this hub change out would be slick if its possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2020 at 8:43pm
Should be as easy as measuring the spindle on the B in the 2 places the bearings run, and measuring the bores in the hub you want to use. Then take your measurements to your local bearing supply company. Motion Industries probably has a bearing that will work.
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2020 at 9:18pm
That was my plan B . Was hoping someone already done the homework , my luck, this research could be a real stinker to work-out . The local parts stores around here just wants you to hand them the part number . They are not much help sometimes.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2020 at 10:08pm
Look up bearing chart on web.     MACK
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2020 at 10:59pm
Burl  I see your problem you are down there in Redneck country!   LOL
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 5:39am
The D10 industrial I have as a project has the larger WC, WD type 5 bolt hubs on it. I haven't had anything apart, although I'd guess that as the parts book shows the same spindles as a regular D10, that just different bearings will do what your're looking to do. I might swap them over to the one CA I have a loader on, if someone doesn't take this parts tractor off my hands.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 6:48am
 Don't use a 'parts store'. Go to Motion Industries in Springfield, or Webb City. Or Springdale, Ar.
https://www.google.com/search?newwindow=1&client=firefox-b-1-d&tbm=lcl&sxsrf=ACYBGNRklErDWoXExN-7Vikr5amAiQqaAg%3A1580042458556&ei=2ogtXovMIZLRtAb34pP4Cw&q=Motion+Industries+near+Aurora+Mo.&oq=Motion+Industries+near+Aurora+Mo.&gs_l=psy-ab.12...0.0.0.325278.0.0.0.0.0.0.0.0..0.0....0...1c..64.psy-ab..0.0.0....0.ltGLijNckOU#rlfi=hd:;si:;mv:[[37.71691842742861,-91.44053937656247],[35.95406565736276,-95.46153547031247],null,[36.840571233675576,-93.45103742343747],8]
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 7:52am
I will get shaft and hub sizes today and see what comes up tomorrow . What I have is a very early series 2 D12 . It has the lighter axle with hubs & bearings same as series 1 and B - C . If this works I can put a set of 16s that came off a D17. Lot easier to find weights for.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 10:21am
Down load the multiple sections of the catalog from http:www.baumhydraulics.com. They search better than their on line stuff. They have a good selection of bearings and of wheel hubs and wheels. They are in Omaha.
Gerald J.
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 3:52pm
Well , this project is over. Worked out bearing issue but , spindle shaft is to short (approx 7/8") to accommodate larger hub. Guess that why no one has already tried it. Poop!!
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 3:57pm
Better to go through to the end, than to give up before every possibility is exhausted. Good on ya, Burl!
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 6:44pm
I've never been that deep, but how does a spindle attach?  Couldn't you just change the spindles?
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 7:03pm
It would be very costly ! The cost of larger spindle, bore out knee (tube spindle slides in ) or replace entire front axle with later model.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 8:16pm
Is there enough room between the small end of the B spindle and the outer bearing bore of whatever hub you want to use to make a stepped nut that is threaded to serve the same purpose ?
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2020 at 8:50pm
That might work but, outer bearing is on some of threaded end and that makes to much clearance between the two surfaces. Kinda loose !
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2020 at 12:55pm
Metal lathe time!Smile
