Whats it fit
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Topic: Whats it fit
    Posted: 23 Jan 2012 at 1:26pm
 I got these piston and sleeve kits off a dealer auction last spring. I can't find what they fit. I do know that they are for a 2800 or 2900 engine but i don't know what fuel. They have a 3 7/8 bore and the outside of the sleeve is the same as one i have for a 190. The part numbers on the sleeve, wrist pin, and rings all come up as for a 180,190. The part im haveing trouble with is the number on the piston and box. The number on the piston is 71365372 and the number on the box is 7136551. I showed them to a old AC mechanic and he said they went to a 190xt gas. I would like to make sure that this is what there for before i try and sell them.    Thanks Matt
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 4:18pm
AGCO's site knows 372 is a piston and 551 a sleave but search eng will not search data base unless you pick a tractor model. checked 170.175,185,190,200,210,220,D19 and could not find a match. David  www.djstractorparts.com
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
190xt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 4:37pm
Hey  Matt do you have any parts for allis 720 garden tractor thanks 190xt if you do could you call. my number is 763 607 1807 thanks
Edited by 190xt - 23 Jan 2012 at 4:40pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 7:58pm
looks like a gas piston to me. but gasoline or LP?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 9:51pm
Definately 301 gas or LPG if the bore is 3 7/8"
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 9:57pm
I can't match them to anything? Are there #'s on the rings, o-rings, or the little yellow bag?
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 9:59pm
Makes sense that the number on the box would be different than the piston.  The box has more than just a piston in it.
