Whats it fit |
Matt (Jordan,MN) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Jordan, MN Points: 3802 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Jan 2012 at 1:26pm |
I got these piston and sleeve kits off a dealer auction last spring. I can't find what they fit. I do know that they are for a 2800 or 2900 engine but i don't know what fuel. They have a 3 7/8 bore and the outside of the sleeve is the same as one i have for a 190. The part numbers on the sleeve, wrist pin, and rings all come up as for a 180,190. The part im haveing trouble with is the number on the piston and box. The number on the piston is 71365372 and the number on the box is 7136551. I showed them to a old AC mechanic and he said they went to a 190xt gas. I would like to make sure that this is what there for before i try and sell them. Thanks Matt
David(Stockbridge)MI ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: Stockbridge MI Points: 536 |
AGCO's site knows 372 is a piston and 551 a sleave but search eng will not search data base unless you pick a tractor model. checked 170.175,185,190,200,210,220,D19 and could not find a match. David www.djstractorparts.com
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler |
190xt ![]() Silver Level ![]() ![]() Joined: 12 Jul 2011 Location: minnesota Points: 97 |
Hey Matt do you have any parts for allis 720 garden tractor thanks 190xt if you do could you call. my number is 763 607 1807 thanks
Edited by 190xt - 23 Jan 2012 at 4:40pm |
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5097 |
looks like a gas piston to me. but gasoline or LP?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21906 |
Definately 301 gas or LPG if the bore is 3 7/8"
Travis(NE) ![]() Silver Level ![]() Joined: 24 Sep 2009 Location: Seward NE Points: 300 |
I can't match them to anything? Are there #'s on the rings, o-rings, or the little yellow bag?
TramwayGuy ![]() Orange Level Access ![]() Joined: 19 Jan 2010 Location: Northern NY Points: 11753 |
Makes sense that the number on the box would be different than the piston. The box has more than just a piston in it.
