What's a B's steering supposed to be like?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: What's a B's steering supposed to be like?
    Posted: 01 Dec 2015 at 4:47pm
Are B's supposed to be real easy to steer? Mine has always required 2 hands just about. I tried putting a spinner knob on it once, and I took it off after about 2 minutes. Actually made it harder. The gear box has plenty of lube in it.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 5:04pm
The military manual says the spindles, tie rod ends, and drag link ends should be greased with chassis grease every 8 hours of operation.TM9-782
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 5:17pm
jack the front end up so the tires are an inch off the ground. you should be able to spin the steering wheel with 2 fingers... If not, remove the steering rod at one end and test the front end and the gear box individually.. Narrow it down to what is dragging.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 6:00pm
They steer pretty easy normally, till you install a loader on em'....  LOL!  Then ya gotta' make sure you're moving first before you turn it. Makes it much easier on you and mostly the steering box!
Dek Thorne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dek Thorne Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 6:47pm
when its moving i can steer mine with one finger
Brighton boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brighton boy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 6:50pm
Same with mine, steers like it has power steering
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 7:35pm
Wow! Sounds like I DEFINITELY have a problem. Thing is, it's been that way since day one, and I never thought anything of it, until a buddy said his new B steered very easily.
Rog(NCWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog(NCWI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2015 at 10:01pm
Check the front bearings. And also when you have the front end off the ground, check the spindles if they are sloppy. I had a CA with a wide front and when a I put new bearings in and rebuilt the spindles you could steer it with one finger.
Edited by Rog(NCWI) - 01 Dec 2015 at 10:02pm
Randy WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2015 at 5:33am
Also you make sure your tires have 1/4 inch toe in. that made a big difference in my Ferguson TO35. as others have said my B will also steer with 1 finger
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2015 at 6:16am
Check air pressure in front tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2015 at 7:40am
I sneaked out to the barn before school and jacked the front up. Still steers about the same.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2015 at 8:19am
Get out the grease gun for a first step.
Gerald J.
