What tractor to use? |
CDR,Ky. ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: N. Kentucky Points: 55 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Aug 2010 at 9:38pm |
I'm thinking of doing garden rototilling and bushoging for a side job and was wondering what size tractor would be good?Maybe a D15 or a 160?Any advice would be appreciated.
If you first don't succeed then you'se brute force!
Claus ![]() Orange Level ![]() ![]() Joined: 09 Dec 2009 Location: Hebron In Points: 1154 |
See what you can find and what your budget can afford. They are both nice size tractors. Do you want a 3pt hitch? If so I would insist on a factory one, gas tractors are easier to fix but that is another option you need to decide what you want. I have always heard the 160 is hard to get parts for. Good luck.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7497 |
I'd definitely go for a 15. The power director would be very handy for use on a tiller. I think an aftermarket 3ph would work just as well as factory.
I hate aftermarket 3pt hitches. Years ago we had a D19 that had an Abott hitch, the tractor had been used on a roto-vator, it was worn out and would come u hooked from the snap-coupler when pulling hard. Besides this the geometry was wrong on it, it was hard to get some tools to lift very high. Another thing, I believe Allis Chalmers tractors had one of the best 3pt hitches on the market.
Sounds like I should stay with the D series.
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
I used to run the D series, then went to the 170/175 diesels. I do tilling and brushhogging for hire, and find it is hard to beat the torque and economy of the Perkins diesels! I gross close to $1000 on every tank of fuel I burn.
ALLIS EXPRESS!
This year: |
clint ![]() Silver Level ![]() Joined: 12 Sep 2009 Location: kentucky Points: 314 |
you want slow ground speed for a tiller- i would go 170/175
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
You might investigate what size gardens you would be doing and the access to them. I have a Case 446 with a Cat 0, 4' hydraulic tiller that works great for a large garden I do. I have plowed and disked it with my D14, but then, I do have room to run around ! In a residential area a large tractor may not work the majority of the time.
