What kind of ripper? |
bakwoodsfarm
Joined: 02 Sep 2010 Location: Woodleaf,NC Points: 511 |
Topic: What kind of ripper?Posted: 23 Nov 2016 at 6:55pm |
I know this has been beat and there are a LOT of variables, but-
never ripped ground, red clay what kind of ripper? in-line/v what size? fresh overhauled 7050 with duals and full front weights or would I be better off with a disk-chisel. I'm pulling a 9 shank 3pt chisel now with no problems, just wanting to get a little deeper. Thanks, Brad |
Dans 7080
Posted: 23 Nov 2016 at 7:51pm |
I run a tye paratill 4 shank 16-18" deep with a 7060 (1000 each side with fluid and duals) 18.4-38s or a 7080 (1000 each side no fluid and duals) 20.8-38s. Both have plenty of power (210 and 300 respectively) traction is more of the issue. The 7060 handles it better. Both have a full rack on the front.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3086 |
Posted: 24 Nov 2016 at 7:58am |
an inline ripper supposedly does better. If the ground is dry, it's supposed to shatter/explode the ground underneath as the inline shanks compresses the dirts between them. A V-ripper doesnt' give you that. We pull a 5-shank with a 200HP 4WD with no problem. I doubt you would want to pull more than a 4. 3-pt would be best.
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 24 Nov 2016 at 9:24am |
pulled a 7 shank deep "V" ripper with my 7080. it was all it wanted as I didn't have a low side of the tranny to pull with. but I could get down 2 ft or better. the farm had never been ripped before in it's life, and boy you could tell it!
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5196 |
Posted: 24 Nov 2016 at 9:53am |
What ever you use wait until the ground is a dry as it can be, that will give you the best benefit.
bakwoodsfarm
Posted: 24 Nov 2016 at 2:14pm |
I've been told the v-rippers pull easier than the inline rippers?
Dans 7080
Posted: 24 Nov 2016 at 3:43pm |
A v ripper will pull easier, but are less effective. You can watch the wave of ground behind mine. You won't see that with a v. The point shank of the v does the most work after that there's room for the dirt to move. Itl just slide it to the side. An inline has no room for the dirt to go but up.
