what is a ca worth
orangeonly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeonly Quote  Post ReplyReply Direct Link To This Post Topic: what is a ca worth
    Posted: 10 Aug 2012 at 10:54pm
there is a guy that has one advertised for 800. says it's runs good
also said he'd trade for guns lol.
If it ain't orange it ain't worth ownin'
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 11:17pm
Sounds good if it runs, but pictures would helpSmile
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeonly Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 11:26pm
it was in the local bulletin board no pics.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 6:01am
You have to go look at it ,check it over ,rear wheels = tires  ( condition),any weight's etc, .
bitburn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitburn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 3:05pm
Some things to look for:
Make sure all the rim stops are not missing.  Should be 4.
Make sure each rim stop has the rim stop pin as well.  Then you could adjust the price of these pieces accordingly if they are missing.
Check for water leaks from the water pump and radiator.
Check the hydraulic fluid, if its milkly white, check the shift boot.  May need a new one.
This page was generated in 0.067 seconds.
